Component: GSM (EB066, Generic AT) (Wireless)
Author Matrix Ltd.
Version 2.0
Category Wireless
GSM (EB066, Generic AT) component
Low level routines for controlling a standard AT GSM / GPRS interface Also available in the form of the EB066 GSM E-block.
Please click here to download the component source project: FC_Comp_Source_GSM.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GSM.fcfx
Example program that checks for network connection and then allows a number to be texted or voice dialled.
Waits for connection to be established before allowing texts or calls to be made.
The number at the top of the file in the calculation icon needs to be edited to a number to connect to for texts and calls.
Arduino Connections:
D8-D13 - LEDs / D8 = Connection Status - Flashing = Connecting / D9 Text sending / D10 Call Active
D0-D7 - GSM
A0-A5 - Switches - A0 = Send Text / A1 = Start voice call / A2 = End call
FC6 Icon.png Arduino GSM Example
PIC Connections
B0-B7 - LEDs / B0 = Connection Status - Flashing = Connecting / B1 Text sending / B2 Call Active
C0-C7 - GSM
A0-A7 - Switches - A0 = Send Text / A1 = Start voice call / A2 = End call
FC6 Icon.png PIC GSM Example
AnswerIncomingCall
Fc9-comp-macro.png AnswerIncomingCall
Answers the phone for an incoming type call. Returns 0 for success and 255 for failure.
CheckForIncoming
Fc9-comp-macro.png CheckForIncoming
Checks to see if any incoming phone call or SMS message. 0 = Nothing, 1 = Text Received, 2 = Phone Ringing
CheckNetworkStatus
Fc9-comp-macro.png CheckNetworkStatus
Returns the state of the GSM network. 0 = Not connected, 1 = connected, 255 = no reply from GSM.
DeleteAllMessages
Fc9-comp-macro.png DeleteAllMessages
Removes all pending text messages from the GSM module. Returns 0 for success and 255 for fail.
DialNumber
Fc9-comp-macro.png DialNumber
Performs a standard voice call by dialling the number specified. Returns 0 for call in progress and 255 for no response.
Fc9-string-icon.png - STRING Number
GetTextNumber
Fc9-comp-macro.png GetTextNumber
Collects the sender's phone number from an incoming text message.
Fc9-u8-icon.png - BYTE NumBytes
GetTextString
Fc9-comp-macro.png GetTextString
Collects the text message data from an incoming text message.
HangUpCall
Fc9-comp-macro.png HangUpCall
Ends a voice based call. Returns 0 for success and 255 for failure.
Fc9-comp-macro.png Initialise
Sets up the GSM module. Returns 0 for OK, 255 for no reply and 254 for command fail.
ReadString
Fc9-comp-macro.png ReadString
Copies the data from the data string array to a local string variable
SendCommand
Fc9-comp-macro.png SendCommand
Sends a command string to the GSM module. 0 = Command sent ok, 255 = No Reply
Fc9-string-icon.png - STRING Command
Fc9-u8-icon.png - BYTE SendCR
SendScript
Fc9-comp-macro.png SendScript
Send an AT command script. Returns 0 for fail, 1 for success and 255 for unrecognised script idx.
Fc9-u8-icon.png - BYTE idx
SendString
Fc9-comp-macro.png SendString
Sends a string to the GSM module.
SendTextMessage
Fc9-comp-macro.png SendTextMessage
Sends the text message data specified to the number specified using the SMS protocol. Returns 0 for success and 255 for failure.
Fc9-string-icon.png - STRING Message
StringReceive
Fc9-comp-macro.png StringReceive
Attempts to receive a string from the GSM modem.
Fc9-type-7-icon.png Expect Echo
Sets if we expect an echo of any data we send out to the GSM modem. Most AT type modems (e.g. GSM modules) will automatically echo back incoming data.
Fc9-type-14-icon.png String Array Size
Amount of RAM memory to dedicate to receiving responces from the GSM
Fc9-type-14-icon.png Message Array Size
Amount of RAM memory to dedicate to storing the last SMS message received by the GSM.
Fc9-type-16-icon.png Script Count
Maximum number of scripts to store in the device's ROM
Fc9-type-11-icon.png Script1
ASCII based AT command data stored in ROM and used when sending script 1
Fc9-type-16-icon.png Channel
Fc9-type-5-icon.png TX
Fc9-type-5-icon.png RX
Fc9-type-16-icon.png Use Flow Control
Fc9-type-16-icon.png Baud Options
Fc9-conn-icon.png Simulation
Fc9-type-10-icon.png Label
Textual label shown on the component I/O flasher
Fc9-type-21-icon.png Console Columns
Fc9-type-16-icon.png Data Source
