Component: WLAN (EB069, WIZ610wi) (Misc)
(Redirected from Component: ID 0dde7075 368e 404c 9d88 d9c6bec55172)
Jump to navigationJump to searchAuthor | Matrix Ltd. |
Version | 1.3 |
Category | Misc |
- 1 WLAN (EB069, WIZ610wi) component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 CheckForPageRequests
- 5.2 ConnectToSSID
- 5.3 DisableCommandMode
- 5.4 EnableCommandMode
- 5.5 GetInValue
- 5.6 GetReply
- 5.7 Initialise
- 5.8 ReadConnectionStatus
- 5.9 ReceiveIncoming
- 5.10 SendCommand
- 5.11 SendString
- 5.12 Send_Embedded_HTML_Page1
- 5.13 Send_Embedded_HTML_Page2
- 5.14 Send_Embedded_HTML_Page3
- 5.15 Send_Embedded_HTML_Page4
- 5.16 SetOutValue
- 6 Property reference
Wireless LAN component designed to work with the WIZ610wi module from Wiznet. Provides a very simple interface to allow webpages to be hosted from hardware or simulation. Also available in the form of the EB069 E-block.
Please click here to download the component source project: FC_Comp_Source_WLAN.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_WLAN.fcfx
CheckForPageRequests | |
To be called periodically. Returns non-zero if a request has been processed | |
- BYTE | Return |
ConnectToSSID
ConnectToSSID | |
Attempts to connect to the given SSID and Key values. Returns 0 if successful. | |
- STRING | SSID |
- STRING | Key |
- BYTE | Return |
DisableCommandMode
DisableCommandMode | |
Exits command mode | |
- VOID | Return |
EnableCommandMode
EnableCommandMode | |
Enables command mode. Must be called before commands are issued. | |
- VOID | Return |
GetInValue
GetInValue | |
Returns the string value of a Request parameter | |
- BYTE | index |
Index of the request paramter, starting at zero. | |
- STRING | Return |
GetReply
GetReply | |
Returns the last received response to a command. 0 = OK 1 = FAIL_ERR 2 = STX_ERR 3 = CMD_ERR 4 = PARAM_ERR 5 = ETX_ERR 6 = SERIAL 255 = TOUT | |
- BYTE | Return |
Initialise | |
Initialise the device with the property data. Returns 0 if successful | |
- BYTE | Return |
ReadConnectionStatus | |
Checks the connection status. Returns 0 if not connected, 1 if connected. | |
- BYTE | Return |
ReceiveIncoming
ReceiveIncoming | |
Returns the received data string | |
- STRING | Return |
SendCommand
SendCommand | |
Sends the given command and returns the reply status. (See GetReply for return values) | |
- STRING | Command |
- BYTE | Return |
SendString
SendString | |
Sends the given Text. Appends a CR/LF pair of characters it CrLf is true. | |
- STRING | Text |
- BYTE | CrLf |
- VOID | Return |
Send_Embedded_HTML_Page1 | |
- VOID | Return |
Send_Embedded_HTML_Page2 | |
- VOID | Return |
Send_Embedded_HTML_Page3 | |
- VOID | Return |
Send_Embedded_HTML_Page4 | |
- VOID | Return |
SetOutValue
SetOutValue | |
Set the value of an outbound substitution string | |
- BYTE | index |
- STRING | value |
- VOID | Return |
