Component: MIAC Serial (MIAC: Addon Modules)
(Redirected from Component: ID 126523d0 e391 4ccb 86c0 0e9d1b33d5f0)
Jump to navigationJump to searchAuthor | |
Version | 1.0 |
Category | MIAC: Addon Modules |
MIAC Serial component
Serial Addon expansion module for MIAC System
FREE
UART_ReceiveChar | |
- BYTE | Timeout |
- UINT | Return |
FAT_OpenFile | |
- STRING | Filename |
- BYTE | Return |
PWM_Enable | |
Enable the PWM on Channel 1 or 2 | |
- BYTE | Channel |
PWM Channel 1 or 2 | |
- VOID | Return |
MI2C_Send_Byte_Transaction | |
[[File:]] - | Device_ID |
[[File:]] - | AddrH |
[[File:]] - | AddrL |
[[File:]] - | Data |
- VOID | Return |
SERIAL_ReceiveChar | |
- BYTE | Timeout |
- UINT | Return |
FAT_Init | |
- BYTE | Return |
SERIAL_SendChar | |
- UINT | Character |
- VOID | Return |
SPI_Uninit | |
- VOID | Return |
MI2C_Stop | |
- VOID | Return |
UART_SendString | |
- STRING | Text |
- VOID | Return |
MIAC_Module_SetData | |
- BYTE | Count |
- BYTE | D0 |
- BYTE | D1 |
- BYTE | D2 |
- BYTE | D3 |
- BYTE | D4 |
- BYTE | D5 |
- VOID | Return |
FAT_ScanCurrentFolder | |
- UINT | idx |
- BYTE | type |
Scan type | |
- BYTE | Return |
MIAC_Module_Init | |
- UINT | CAN_ID |
- VOID | Return |
MIAC_Module_GetData | |
- BYTE | Index |
- BYTE | Return |
SPI_Init | |
- VOID | Return |
FAT_AppendStringToFile | |
- STRING | Text |
- BYTE | Return |
MIAC_Module_Message | |
- UINT | CAN_ID |
- UINT | CMD_ID |
- BYTE | Return |
MIAC_Module_WR | |
- UINT | CAN_ID |
- UINT | CMD_ID |
[[File:]] - | Count |
[[File:]] - | Start |
[[File:]] - | More |
- VOID | Return |
MI2C_Restart | |
- VOID | Return |
FAT_OpenFolder | |
- STRING | Folder |
- BYTE | Return |
LED_Control | |
Sets the indicator LED On (State=1) or Off (State=0) | |
- BYTE | State |
- VOID | Return |
SPI_Get_Char | |
[[File:]] - | Return |
UART_Initialize | |
- VOID | Return |
FAT_MoveToNextFileSector | |
- BYTE | force |
force next sector | |
- BYTE | Return |
FAT_ReadByteFromScan | |
- UINT | idx |
- BYTE | Return |
SPI_Send_Char | |
[[File:]] - | Char |
- VOID | Return |
FAT_ReadFileLength | |
- UINT | Return |
MI2C_Transmit_Byte | |
FAT_CreateFile | |
- BYTE | Return |
MIAC_Module_PushData | |
- BYTE | Data |
- VOID | Return |
MI2C_Receive_Byte | |
[[File:]] - | Last |
- BYTE | Return |
MI2C_Init | |
- VOID | Return |
PWM_Disable | |
Disable the PWM on Channel 1 or 2 | |
- BYTE | Channel |
- VOID | Return |
SERIAL_ReceiveString | |
- BYTE | Timeout |
- BYTE | NumBytes |
- STRING | Return |
FAT_WriteFileSector | |
- BYTE | Return |
SERIAL_SendString | |
- STRING | Text |
- VOID | Return |
MI2C_Receive_Byte_Transaction | |
DigitalOutput | |
Set a Terminal Output to High (Value=1) or Low (Value=0) | |
- BYTE | Terminal |
- BYTE | Value |
- BYTE | Return |
FAT_ReadByteFromBuffer | |
- UINT | address |
- BYTE | Return |
MIAC_Module_GetAck | |
- UINT | CAN_ID |
- UINT | CMD_ID |
- UINT | TimeOut |
- BYTE | Return |
FAT_ReadFileSector | |
- BYTE | Return |
FAT_WriteByteToBuffer | |
- UINT | address |
- BYTE | data |
- VOID | Return |
SERIAL_Initialize | |
- VOID | Return |
FAT_DeleteFile | |
- BYTE | Return |
AnalogInput | |
Read the ADC value of a Terminal Returns 12 bit ADC reading | |
- BYTE | Terminal |
Terminal number to be read | |
- UINT | Return |
Initialize | |
Forces a software reset on the module | |
- VOID | Return |
UART_ReceiveString | |
- BYTE | Timeout |
- BYTE | NumBytes |
- STRING | Return |
PWM_SetDuty | |
Sets the PWM Duty cycle on Channel 1 or 2 | |
- BYTE | Channel |
- BYTE | Duty |
Duty cycle (8 bit value) | |
- VOID | Return |
MI2C_Start | |
- VOID | Return |
DigitalInput | |
Read the value of a terminal | |
- BYTE | Terminal |
- BYTE | Return |
UART_SendChar | |
- VOID | Return |
