Component: RGB LED LP5030 LP5036 (LEDs)
(Redirected from Component: ID 12a23e2a 0b1e 427e 975a f0b56d4a9483)
Version | 1.0 |
Category | LEDs |
RGB LED LP5030 LP5036 component
An I2C Based RGB LED driver with 30 or 36 individual constant-current sinks. Used to drive 10 or 12 RGB LEDs with a wide range of applications.
Please click here to download the component source project: FC_Comp_Source_LP5036_RGB_LED.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LP5036_RGB_LED.fcfx
GetBrightness
GetBrightness | |
Gets the brightness of a single LED. | |
- BYTE | Address |
Range: 0-11 | |
- BYTE | RGB |
Byte array containing at least 3 bytes to store Red, Green and Blue | |
- BYTE | Return |
GetDiscreteRGB
GetDiscreteRGB | |
Gets the RGB format colour of a single LED. | |
- BYTE | Address |
Range: 0-11 | |
- BYTE | ColourIndex |
- BYTE | Return |
GetRGB
Initialise | |
Starts up the I2C comms ready for communicating with the LP503x module. Must be called before any of the other component macros are called. | |
- VOID | Return |
ReadReg
ReadReg | |
Reads the data from one or more sequential registers | |
- BYTE | Address |
- BYTE | Data |
- BYTE | Count |
- VOID | Return |
SetBrightness
SetDiscreteRGB
SetDiscreteRGB | |
Allows the colour of a single LED to be specified in RGB format | |
- BYTE | Address |
Range: 0-11 | |
- BYTE | Red |
- BYTE | Green |
- BYTE | Blue |
- VOID | Return |
SetRGB
SetUnitAddress
SetUnitAddress | |
Allows the component to taklk to more then one IC or broadcast to all connected ICs. | |
- BYTE | Address |
Range: 0-3 = Individual / 4 = Broadcast | |
- VOID | Return |
WriteReg
WriteReg | |
Writes data to one or more sequential registers | |
- BYTE | Address |
- BYTE | Data |
- BYTE | Count |
- VOID | Return |
