Component: Keypad (Hex 4x4) (Keypad)
(Redirected from Component: ID 287e2f0b 8869 4994 a958 c8f851091322)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.0 |
Category | Keypad |
Keypad (Hex 4x4) component
Preset keypad for entering hexadecimal numbers. Macros 'GetIndex' or 'GetNumber' will return the decimal equivalent of the number pressed, or 255 when no key is pressed. 'GetString' will return the character, including 'ABCDEF'.
Please click here to download the component source project: FC_Comp_Source_keypad_hex.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_keypad_hex.fcfx
GetAscii
GetAscii | |
Gets the ASCII value for the current keypress. If no key is pressed then the macro returns the value 255. | |
- BYTE | Return |
GetIndex
GetIndex | |
Gets the index value for the current keypress. If no key pressed then the macro returns the value 255. | |
- BYTE | Return |
GetNumber
GetNumber | |
Gets the numeric value for the current keypress. If no key pressed then the macro returns the value 255. | |
- BYTE | Return |
GetString
GetString | |
Gets the ASCII value for the current keypress and returns in the form of a string. If no key pressed then the macro returns a null string. | |
- STRING | Return |
WaitPressed
WaitPressed | |
Blocking call that waits for one of the keys on the keypad to be pressed. The index of the key that was pressed is passed back to the user. | |
- BYTE | Return |
WaitReleased
WaitReleased | |
Blocking call that waits for the keys on the keypad to be released. If no key is pressed then the function will return immediatley. | |
- VOID | Return |
