Component: LTSR Current Transducer (Electrical)
Author medelec35
Category Electrical
LTSR Current Transducer component
LTSR rage of +/- 6, 15 & 25A current Tranducers
Please click here to download the component source project: FC_Comp_Source_LTSR_Current_Transducer.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LTSR_Current_Transducer.fcfx
Current
Fc9-comp-macro.png Current
Fc9-type-16-icon.png Device
Fc9-type-15-icon.png VDD
Fc9-type-6-icon.png Channel
