Component: IO Expander (MCP23S17) (MCP23S17) (General Input)
Category General Input
IO Expander (MCP23S17) component
Provides 16 digital input/output pins arranged into two 8-bit ports using a SPI bus connection. Multiple expanders can be connected to the same SPI peripheral by means of individual chip select pins.
Please click here to download the component source project: FC_Comp_Source_MCP23S17.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_MCP23S17.fcfx
ConfigureInversion
Fc9-comp-macro.png ConfigureInversion
Configures the pin inversion for the two ports. Disabled on all pins by default.
Fc9-u8-icon.png - BYTE PortA
Port A inversion sent as an 8-bit value, 0 = Disabled, 1 = Enabled
Fc9-u8-icon.png - BYTE PortB
Port B inversion sent as an 8-bit value, 0 = Disabled, 1 = Enabled
ConfigurePullups
Fc9-comp-macro.png ConfigurePullups
Configures the pullups for the two ports. Disabled on all pins by default.
Port A pull ups sent as an 8-bit value, 0 = Disabled, 1 = Enabled
Port B pull ups sent as an 8-bit value, 0 = Disabled, 1 = Enabled
Fc9-comp-macro.png Initialise
ReadPort
Fc9-comp-macro.png ReadPort
Reads a value to one of the ports with a mask. Configures the masked bits to be inputs before reading the input value.
0=PortA, 1=PortB
Fc9-u8-icon.png - BYTE Mask
Allows port bits to be modified without effecting other bits, 255 = write full port.
ReadPortPin
Fc9-comp-macro.png ReadPortPin
Reads a single port pin from one of the ports. Configures the pins to be an input before reading the input value. Returns 0 or 1 corresponding to the value on the port pin.
0=PortA, 1=PortB
Fc9-u8-icon.png - BYTE Pin
Port pin to read. Range: 0-7
ReadRegister
Fc9-comp-macro.png ReadRegister
Reads an 8-bit value from a register on the I/O expander device.
Register address to write to. Range: 0-15
WritePort
Fc9-comp-macro.png WritePort
Writes a value to one of the ports with a mask. Configures the masked bits to be outputs before writing the output value.
0=PortA, 1=PortB
Fc9-u8-icon.png - BYTE Value
Value to write. Range 0-255
WritePortPin
Fc9-comp-macro.png WritePortPin
Writes a single port pin on one of the ports. Configures the pins to be an output before writing the input value.
0=PortA, 1=PortB
Value to output on the selected pin. Range: 0-1
WriteRegister
Fc9-comp-macro.png WriteRegister
Writes an 8-bit value to a register on the I/O expander device.
Value to write. Range: 0-255
Fc9-conn-icon.png SPI Communications
Fc9-type-16-icon.png External Address
Selects the value of the three address pins for the MCP23S17.
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-5-icon.png MOSI
Fc9-type-5-icon.png MISO
Fc9-type-5-icon.png CLK
Fc9-type-5-icon.png CS / SS
Fc9-type-7-icon.png Use Reset
Fc9-conn-icon.png Simulation
Fc9-type-10-icon.png Label
Fc9-type-16-icon.png API
