Component: Input ADC (DSP Inputs)
Version 1.2
Category DSP Inputs
Input ADC component
Allows the values from a buffer to be assigned driectly from an analog enabled pin. Either a single sample at a time or a number of samples. Auto scales the digital value to fill the entire range of the specified buffer type.
Please click here to download the component source project: FC_Comp_Source_DSP_ADCInput.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_ADCInput.fcfx
AddSample
Fc9-comp-macro.png AddSample
Adds a single ADC sample to the current location in the specified buffer. If Auto Scale is enabled then the sample will be scaled to correctly fit inside the buffer. Auto increments current location.
AddSampleArray
Fc9-comp-macro.png AddSampleArray
Fc9-u16-icon.png - UINT SampleDelay
Number of us in between each sample.
Fc9-type-16-icon.png Buffer Type
Sets the buffer data type, data is automatically scaled to fit and make full use of the data type.
Fc9-type-6-icon.png Channel
Fc9-conn-icon.png Settings
Fc9-type-21-icon.png Bit Depth
Maximum number of bits for each ADC sample.
Fc9-type-7-icon.png Remap Values
Map the analog input range to a selected output range.
Fc9-conn-icon.png Mapping
Fc9-type-7-icon.png Input Full Range
Selects if the entire range of the ADC is mapped. Yes: Use the full ADC range No: Use a custom ADC range
Fc9-type-21-icon.png Input Min
Min value provided by the ADC input
Fc9-type-21-icon.png Input Max
Max value provided by the ADC input
Fc9-type-14-icon.png Output Min
Min value to output
Fc9-type-14-icon.png Output Max
Max value to output
Fc9-conn-icon.png Simulation Slider
Fc9-type-7-icon.png Show Slider
Allows the ADC input to be driven from a slider.
Fc9-type-21-icon.png Major Tick Step
The number of minor tick marks to show a major tick mark value.
Fc9-type-15-icon.png Minor Tick Step
The scale value between consecutive minor tick marks.
Fc9-type-10-icon.png Label Format
