Component: Serial EEPROM (24C32) (EEPROM)
Version 2.2
Category EEPROM
Serial EEPROM (24C32) component
Serial (I2C) EEPROM component for 24C32 Can be added to a MIAC project to give read and write access to the internal non-volatile memory device (if fitted, depending upon model).
Please click here to download the component source project: FC_Comp_Source_Serial_EEPROM_(24C32).fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Serial_EEPROM_(24C32).fcfx
Read
Fc9-comp-macro.png Read
Read and return the value of the EEPROM at the given address
Fc9-u16-icon.png - UINT address
Write
Fc9-comp-macro.png Write
Write the given data value to the EEPROM at the given address
Fc9-u8-icon.png - BYTE data
Fc9-type-16-icon.png Device Address
Device address bits, these must match the address pins on the EEPROM IC.
Fc9-type-16-icon.png Channel
Channel selection
Baud rate to be used
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Fc9-conn-icon.png Simulation
