Component: TCP/IP (EB023 v2) (E-blocks 1)
Version 2.0
Category E-blocks 1
TCP/IP component
TCP/IP component designed to work with the WIZ810MJ module from Wiznet, as used on version 2 EB023 E-block and the MIAC Industrial Addon module.
Please click here to download the component source project: FC_Comp_Source_TCPIP_EB023-00-2_EB.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TCPIP_EB023-00-2_EB.fcfx
CreateIPSocket
Fc9-comp-macro.png CreateIPSocket
Note that sockets on up to 4 channels can be simultaneously opened and these channels are numbered 0 to 3. Note that sockets with different modes can be opened on different channels.
Specifies the communications channel 0-3
Fc9-u8-icon.png - BYTE Protocol
Specifies which IP protocol to use
Fc9-u8-icon.png - BYTE Broadcast
Allows broadcast type packets to be sent and received
CreateMACSocket
Fc9-comp-macro.png CreateMACSocket
This macro creates a socket for sending and receiving Ethernet data using raw data.
Fc9-u8-icon.png - BYTE Promiscuous
Receive everything (1) or just data bound for your MAC (0)
Allows broadcast messages to be accepted (1) or rejected (0)
Fc9-u8-icon.png - BYTE Error
Allowsmessages with errors to be accepted (1) or rejected (0)
CreateTCPSocket
Fc9-comp-macro.png CreateTCPSocket
This macro creates a socket for sending and receiving TCP data.
Fc9-u16-icon.png - UINT Src_Port
Port Number
CreateUDPSocket
Fc9-comp-macro.png CreateUDPSocket
This macro creates a socket for sending and receiving UDP data.
Port Number
CreateUDPSocket_Sim
Fc9-comp-macro.png CreateUDPSocket_Sim
Port Number
GetSocketStatus
Fc9-comp-macro.png GetSocketStatus
This returns the state of the requested channel's socket.
Fc9-comp-macro.png Initialise
MIAC_Module_GetData
Fc9-comp-macro.png MIAC_Module_GetData
Fc9-u8-icon.png - BYTE Index
MIAC_Module_Message
Fc9-comp-macro.png MIAC_Module_Message
Fc9-u16-icon.png - UINT CAN_ID
Fc9-u16-icon.png - UINT CMD_ID
MIAC_Module_PushData
Fc9-comp-macro.png MIAC_Module_PushData
Fc9-u8-icon.png - BYTE Data
MIAC_Module_SetData
Fc9-comp-macro.png MIAC_Module_SetData
Fc9-u8-icon.png - BYTE Count
Fc9-u8-icon.png - BYTE D0
Fc9-u8-icon.png - BYTE D1
Fc9-u8-icon.png - BYTE D2
Fc9-u8-icon.png - BYTE D3
Fc9-u8-icon.png - BYTE D4
Fc9-u8-icon.png - BYTE D5
RxDataAvailable
Fc9-comp-macro.png RxDataAvailable
This macro is used to check whether or not data has been received by the Internet E-Block. A return value of zero indicated that no data has been received. A positive return value indicates that data is available.
RxDataSize
Fc9-comp-macro.png RxDataSize
This macro is used to detect the size of data collected by the Rx_data_available macro.
RxDataSize_Sim
Fc9-comp-macro.png RxDataSize_Sim
RxFlushData
Fc9-comp-macro.png RxFlushData
Once data reception has been completed, this macro should be called to discard the data packet and allow other data packets to be read.
RxFlushData_Sim
Fc9-comp-macro.png RxFlushData_Sim
RxMatchMyIP
Fc9-comp-macro.png RxMatchMyIP
This macro returns a non-zero value when the next 4 bytes of data in the specified channel's reception buffer are the same as the Internet E-block's IP address.
RxMatchMyMAC
Fc9-comp-macro.png RxMatchMyMAC
This macro returns a non-zero value when the next 6 bytes of data in the specified channel's reception buffer are the same as the Internet E-block's MAC address entered in the component's property page.
RxMatchMyMAC_Sim
Fc9-comp-macro.png RxMatchMyMAC_Sim
RxMatch_2_Bytes
Fc9-comp-macro.png RxMatch_2_Bytes
This macro returns a non-zero value when the next 2 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 4 bytes and 6 bytes.
Fc9-u8-icon.png - BYTE Byte1
Specifies the value of the first byte
Fc9-u8-icon.png - BYTE Byte2
Specifies the value of the second byte
RxMatch_2_Bytes_Sim
Fc9-comp-macro.png RxMatch_2_Bytes_Sim
RxMatch_4_Bytes
Fc9-comp-macro.png RxMatch_4_Bytes
This macro returns a non-zero value when the next 4 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 2 bytes and 6 bytes.
Fc9-u8-icon.png - BYTE Byte3
Specifies the value of the third byte
Fc9-u8-icon.png - BYTE Byte4
Specifies the value of the fourth byte
RxMatch_4_Bytes_Sim
Fc9-comp-macro.png RxMatch_4_Bytes_Sim
RxMatch_6_Bytes
Fc9-comp-macro.png RxMatch_6_Bytes
This macro returns a non-zero value when the next 6 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 2 bytes and 4 bytes.
Fc9-u8-icon.png - BYTE Byte5
Specifies the value of the fifth byte
Fc9-u8-icon.png - BYTE Byte6
Specifies the value of the sixth byte
RxReadByte
Fc9-comp-macro.png RxReadByte
A call to this macro will return a byte of data in the reception buffer of the specified channel. It will also internally increment a pointer to that data so that the next call to 'Rx_readbyte' (or any other read function) will read the next byte
RxReadByte_Sim
Fc9-comp-macro.png RxReadByte_Sim
RxReadHeader
Fc9-comp-macro.png RxReadHeader
Once data in a particular channel has been received, the header will be filled with information about the received data. This macro will return the information in the header. The idx parameter specifies which byte of information in the header to read
Fc9-u8-icon.png - BYTE Idx
Specifies the byte index to return
RxReadString
Fc9-comp-macro.png RxReadString
A call to this macro will return a string of data in the reception buffer of the specified channel. It will also internally increment a pointer to that data so that the next call to 'Rx_readbyte' (or any other read function) will read the next byte
Fc9-u8-icon.png - BYTE Length
RxSkipBytes
Fc9-comp-macro.png RxSkipBytes
Often when receiving data packets, it may be necessary to ignore large sections of the data. This can be achieved by reading each byte individually (and ignoring the returned data), but a better way is to use this Rx_skipbytes macro.
Specifies how many bytes to skip
SetDestination
Fc9-comp-macro.png SetDestination
This is used in IP and UDP modes to set the destination of the intended data transfer. The destination IP address needs to be set for both IP and UDP modes.
Fc9-u8-icon.png - BYTE Dst_IP0
Specifies the first byte of an IP address
Fc9-u8-icon.png - BYTE Dst_IP1
Specifies the second byte of an IP address
Fc9-u8-icon.png - BYTE Dst_IP2
Specifies the third byte of an IP address
Fc9-u8-icon.png - BYTE Dst_IP3
Specifies the fourth byte of an IP address
Fc9-u16-icon.png - UINT Dst_Port
Destination Port
SetGateway
Fc9-comp-macro.png SetGateway
This macro sets up the Internet E-Block's Gateway address. In most circumstances, this macro will not be required as the gateway address setting in the component property page will remain constant throughout your application.
Fc9-u8-icon.png - BYTE IP0
First Byte of IP address
Fc9-u8-icon.png - BYTE IP1
Second Byte of IP address
Fc9-u8-icon.png - BYTE IP2
Third Byte of IP address
Fc9-u8-icon.png - BYTE IP3
Fourth Byte of IP address
SetMACAddress
Fc9-comp-macro.png SetMACAddress
This macro sets up the Internet E-Block's MAC address. In most circumstances, this macro will not be required as the MAC address setting in the component property page will remain constant throughout your application.
Fc9-u8-icon.png - BYTE MAC0
First Byte of address
Fc9-u8-icon.png - BYTE MAC1
Second Byte of address
Fc9-u8-icon.png - BYTE MAC2
Third Byte of address
Fc9-u8-icon.png - BYTE MAC3
Fourth Byte of address
Fc9-u8-icon.png - BYTE MAC4
Fc9-u8-icon.png - BYTE MAC5
Fifth Byte of address
SetMyIP
Fc9-comp-macro.png SetMyIP
This macro sets up the Internet E-Block's own IP address. In most circumstances, this macro will not be required as the IP address setting in the component property page will remain constant throughout your application.
SetSubnetMask
Fc9-comp-macro.png SetSubnetMask
This macro sets up the Internet E-Block's Subnet Mask. In most circumstances, this macro will not be required as the subnet mask setting in the component property page will remain constant throughout your application.
TCPClose
Fc9-comp-macro.png TCPClose
When an established TCP connection has finished transmission of data, either the local application (i.e. your code) or the remote application (i.e. the application at the other end of the connection) can initiate closure of the socket.
TCPConnect
Fc9-comp-macro.png TCPConnect
This macro puts a previously opened TCP channel in "active open" mode. This is the required mode when writing a TCP client application (e.g. using SMTP to send an email).
Destination Port
TCPListen
Fc9-comp-macro.png TCPListen
This macro puts a previously opened TCP channel in "passive open" mode. This is the required mode when writing a TCP server application (e.g. a web server to display HTML web pages).
TxEnd
Fc9-comp-macro.png TxEnd
Once the transmit buffer has been filled with data, call this macro to actually send the data.
TxSendByte
Fc9-comp-macro.png TxSendByte
This macro fills the specified channel's transmit buffer with data. It can fill the buffer with a single byte of data, or with a string of information.
Data byte to append to Tx buffer.
TxSendByte_Sim
Fc9-comp-macro.png TxSendByte_Sim
TxSendMyIP
Fc9-comp-macro.png TxSendMyIP
This macro fills the specified channel's transmit buffer with 4 bytes of data representing this Internet E-Block's IP address as specified in the component's property page.
TxSendMyMAC
Fc9-comp-macro.png TxSendMyMAC
This macro fills the specified channel's transmit buffer with 6 bytes of data representing this Internet E-Block's MAC address as specified in the component's property page.
TxSendString
Fc9-comp-macro.png TxSendString
This macro fills the specified channel's transmit buffer with data. It can fill the buffer with a string of information.
TxStart
Fc9-comp-macro.png TxStart
This macro indicates the start of data transmission for the specified buffer. In TCP mode, data transmission can only begin once the socket has become established. In other modes, data transmission can occur as soon as the socket has been opened.
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-5-icon.png MOSI
Fc9-type-5-icon.png MISO
Fc9-type-5-icon.png CLK
Fc9-type-5-icon.png CS / SS
Fc9-conn-icon.png Gateway IP
Fc9-type-14-icon.png Gateway0
Fc9-type-14-icon.png Gateway1
Fc9-type-14-icon.png Gateway2
Fc9-type-14-icon.png Gateway3
Fc9-conn-icon.png Subnet Mask
Fc9-type-14-icon.png Subnet0
Fc9-type-14-icon.png Subnet1
Fc9-type-14-icon.png Subnet2
Fc9-type-14-icon.png Subnet3
Fc9-conn-icon.png IP Address
Fc9-type-14-icon.png IP0
Fc9-type-14-icon.png IP1
Fc9-type-14-icon.png IP2
Fc9-type-14-icon.png IP3
Fc9-conn-icon.png MAC Address
Fc9-type-14-icon.png MAC0
Fc9-type-14-icon.png MAC1
Fc9-type-14-icon.png MAC2
Fc9-type-14-icon.png MAC3
Fc9-type-14-icon.png MAC4
Fc9-type-14-icon.png MAC5
Fc9-conn-icon.png Simulation
Fc9-type-10-icon.png Label
Fc9-type-16-icon.png Sim Type
Decides how to perform the simulation of the component. TCP IP - Communicates using the Windows TCP IP communications DLL SPI / API - Communicates using the CAL SPI to allow the communications to be analysed and debugged.
Fc9-conn-icon.png SPI Simulation
Fc9-type-16-icon.png API
