Component: DC Motor ()
(Redirected from Component: ID 3becc5a1 4034 45ca b84f d995c6cacdb2)
Jump to navigationJump to searchAuthor | Matrix Ltd. |
Version | 1.2 |
Category |
DC Motor component
DC Motor that can be driven in one or both directions using digital output pins, PWM or HBRIDGE peripherals.
Please click here to download the component source project: FC_Comp_Source_Motor_with_reverse.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Motor_with_reverse.fcfx
Simple example showing how to drive the motor components and how to create sub assemblies attached to the motor output shafts in the simulation panels. Motors
Break
Break | |
Actively drives both ends of the motor by setting the pins according to the 'Brake Pattern' property. | |
- VOID | Return |
Coast
Coast | |
Turn off power to the motor by setting the pins according to the 'Coast Pattern' property. | |
- VOID | Return |
Disable
Disable | |
Disable the motor output | |
- VOID | Return |
Enable
Enable | |
Enables the motor output | |
- VOID | Return |
Forwards
Forwards | |
Set the motor turning in the forwards direction by setting the pins according to the 'Reverse Pattern' property. | |
- UINT | Duty |
Sets the motor power for PWM or H-Bridge outputs | |
- VOID | Return |
Reverse
Reverse | |
Set the motor turning in the reverse direction by setting the pins according to the 'Reverse Pattern' property. | |
- UINT | Duty |
- VOID | Return |
