Component: TTI TG5011 Signal Generator (TG5011) (Test Equipment)
Version 0.2
Category Test Equipment
TTI TG5011 Signal Generator component
TTi TG5011 50 MHz Signal Generator
Please click here to download the component source project: FC_Comp_Source_TTITG5011.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_TTITG5011.fcsx
ADDRESSRet
Fc9-comp-macro.png ADDRESSRet
Returns the instruments address
Fc9-s16-icon.png - INT Return
AMPL
Fc9-comp-macro.png AMPL
Sets the amplitde to <nrf> in the units as specified by the AMPUNIT command. (Range = 10mVpp - 10Vpp)
Fc9-f32-icon.png - FLOAT Amplitude
Sets the amplitude (10mVpp - 10Vpp). Units specificied by AMPUNIT command.
AMPLRNG
Fc9-comp-macro.png AMPLRNG
Sets the amplitude range to; 0 = AUTO, 1 = HOLD.
Fc9-bool-icon.png - BOOL Range
Sets the amplitude range (0 = AUTO, 1 = HOLD).
AMPUNIT
Fc9-comp-macro.png AMPUNIT
Sets the amplitude units to; 0 = VPP, 1 = VRMS, 2 = DBM.
Fc9-u8-icon.png - BYTE Units
Sets the amplitude units (0 = VPP, 1 = VRMS, 2 = DBM).
ARB1
Fc9-comp-macro.png ARB1
Loads the binary-data to an existing arbitrary waveform memory location ARB1.
Fc9-u16-icon.png - UINT Waveform
16 Bit binary number for arbitrary waveform.
ARB1DEFRet
Fc9-comp-macro.png ARB1DEFRet
Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB1.
ARB1Ret
Fc9-comp-macro.png ARB1Ret
Returns the binary-data from an existing abbitrary wavefrom memory location.
ARB2
Fc9-comp-macro.png ARB2
Loads the binary-data to an existing arbitrary waveform memory location ARB2.
ARB2DEFRet
Fc9-comp-macro.png ARB2DEFRet
Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB2.
ARB2Ret
Fc9-comp-macro.png ARB2Ret
ARB3
Fc9-comp-macro.png ARB3
Loads the binary-data to an existing arbitrary waveform memory location ARB3.
ARB3DEFRet
Fc9-comp-macro.png ARB3DEFRet
Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB3.
ARB3Ret
Fc9-comp-macro.png ARB3Ret
ARB4
Fc9-comp-macro.png ARB4
Loads the binary-data to an existing arbitrary waveform memory location ARB4.
Fc9-u8-icon.png - BYTE Waveform
ARB4DEFRet
Fc9-comp-macro.png ARB4DEFRet
Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB4.
ARB4Ret
Fc9-comp-macro.png ARB4Ret
ARBDCOFFS
Fc9-comp-macro.png ARBDCOFFS
Sets the arbritary dc waveform offset to <nrf> volts.
Fc9-f32-icon.png - FLOAT OffsetVoltage
Set the offset voltage
ARBDEF
Fc9-comp-macro.png ARBDEF
Sets user specified waveform name <cpd2> and waveform point interpollation state <cpd3> of arbitrary waveform memory location <cpd1>.
Fc9-string-icon.png - STRING Name
Specified waveform name
Fc9-string-icon.png - STRING State
Waveform interpolatino state
Fc9-string-icon.png - STRING Location
Waveform memory location
ARBLOAD
Fc9-comp-macro.png ARBLOAD
<cpd> sets the output waveform type to <DC>,<SINC>, <EXPRISE>,<LOGRISE>,<RAMPUP>,<RAMPDN>, <TRIANG>,<SQUARE>, <ARB1>,<ARB2>,<ARB3>, <ARB4>, <"USERNAME1">, <"USERNAME2">, <"USERNAME3">, <"USERNAME4">.
Fc9-string-icon.png - STRING Type
Waveform Type
ARBRESIZE
Fc9-comp-macro.png ARBRESIZE
Changes the size of arbritary waveform <cpd> to <nrf>.
Fc9-f32-icon.png - FLOAT Size
Size of waveform
Fc9-string-icon.png - STRING Waveform
Arbritary Waveform
BEEP
Fc9-comp-macro.png BEEP
Sound one beep.
BEEPMODE
Fc9-comp-macro.png BEEPMODE
Set beep mode to; 0 = ON, 1 = OFF, 2 = WARN, 3 = ERROR.
Fc9-u8-icon.png - BYTE Mode
Sets the beep mode (0 = ON, 1 = OFF, 2 = WARN, 3 = ERROR).
BST
Fc9-comp-macro.png BST
Sets the burst mode to; 0 = <OFF>, 1 = <NCYC>, 2= <GATED>, 3 = <INFINITE>.
Fc9-u8-icon.png - BYTE MODE
Sets the burst mode (0 = OFF, 1 = NCYC, 2 = GATED, 3 = INFINITE).
BSTCOUNT
Fc9-comp-macro.png BSTCOUNT
Sets the burst count to <nrf> cycles, maximum 1048575 cycles.
Fc9-s32-icon.png - LONG Count
Sets the burst count in cycles (1 - 1048575).
BSTPER
Fc9-comp-macro.png BSTPER
Sets the burst trigger period to <nrf> seconds. (Lower limit: 1us - Upper limit: 500s).
Fc9-f32-icon.png - FLOAT Seconds
Duration of the burst trigger period in seconds.
BSTPHASE
Fc9-comp-macro.png BSTPHASE
Sets the burst phase to <nrf> degrees. (Lower limit: -360 - Upper limit: 360)
Fc9-f32-icon.png - FLOAT Degrees
Sets the burst phase in degrees (-360 - 360)
BSTTRGPOL
Fc9-comp-macro.png BSTTRGPOL
Sets the burst trigger slope to; 0 = POS, 1 = NEG.
Fc9-bool-icon.png - BOOL Slope
Set the burst trigger slope (0 = POS, 1 = NEG).
BSTTRGSRC
Fc9-comp-macro.png BSTTRGSRC
Sets the burst trigger source to; 0 = INT, 1 = EXT, 2 = MAN.
Fc9-u8-icon.png - BYTE Source
Set the burst trigger source (0 = INT, 1 = EXT, 2 = MAN).
CALADJ
Fc9-comp-macro.png CALADJ
Adjust the selected calibration value by <nrf> (Lower limit: -100 - Upper limit: 100).
Fc9-f32-icon.png - FLOAT Calibrate
Adjust the selected calibration value (-100 - 100).
CALIBRATION
Fc9-comp-macro.png CALIBRATION
Sets the calibration mode to <START>, <SAVE>, or <ABORT>. <nrf> represents the calibration password.
0 = START, 1 = SAVE, 2 = ABORT
Fc9-u32-icon.png - ULONG Password
Calibration password
CALSTEP
Fc9-comp-macro.png CALSTEP
Step to the next calibration point.
CALVALRet
Fc9-comp-macro.png CALVALRet
Returns the value from level calibration steps.
CLKSRC
Fc9-comp-macro.png CLKSRC
Sets the clock source to; 0 = INT, 1 = EXT.
Fc9-bool-icon.png - BOOL Source
Sets the clock source (0 = INT, 1 = EXT).
CLKSRRet
Fc9-comp-macro.png CLKSRRet
Returns the clock source <INT> or <EXT>.
CLS
Fc9-comp-macro.png CLS
Clears status byte register of the interface.
DCOFFS
Fc9-comp-macro.png DCOFFS
Sets the dc offset to <nrf> Volts. (Lower limit: -4.500 Vdc - Upper limit: 4.500 Vdc).
Fc9-f32-icon.png - FLOAT DCOffset
Sets the dc offset in Volts(Vdc) (4.500 Vdc - 4.500 Vdc).
EERRet
Fc9-comp-macro.png EERRet
Query and clear execution error number register.
ESE
Fc9-comp-macro.png ESE
Sets the Standard Event Status Enable Register to the value of <nrf>.
Fc9-u8-icon.png - BYTE Value
Value of register 0-255
ESERet
Fc9-comp-macro.png ESERet
Returns the value in the Standard Event Status Enable Register in <nr1> numeric format. The syntax of the response is <nr1><rmt>.
ESESet
Fc9-comp-macro.png ESESet
Sets the standard event status enable register to the value of <nrf>. (Lower limit: 0 - Upper limit: 255)
Enable the register to this value. (0 - 255)
ESRRet
Fc9-comp-macro.png ESRRet
Returns the value in the standard event status register in <nr1>
FREQ
Fc9-comp-macro.png FREQ
Set the waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 50MHz).
Fc9-f32-icon.png - FLOAT Frequency
Sets the waveform frequency in Hertz(Hz) (1uHz - 50MHz).
HILVL
Fc9-comp-macro.png HILVL
Sets the amplitude-high-level to <nrf> Volts. (Lower limit: -0.490 V - Upper limit: 5.000 V).
Fc9-f32-icon.png - FLOAT HighLevel
Sets the amplitude-high-level in Volts(V) (-0.490 V - 5.000 V).
IDNRet
Fc9-comp-macro.png IDNRet
Returns the instrument identification. The IDN is saved to the variable passed from the function 'ReturnIDN'. The return parameter is TRUE when the IDN is successfully returned.
Fc9-string-icon.png - STRING ReturnIDN
ISTRet
Fc9-comp-macro.png ISTRet
Returns IST local message as defined by IEEE Std. 488.2. The syntax of the response is 0<rmt>, if the local message is false, or 1<rmt>, if the local message is true.
LOCAL
Fc9-comp-macro.png LOCAL
Returns the instrument to local opertion and unlocks the keyboard.
LOCKMODE
Fc9-comp-macro.png LOCKMODE
Sets the synchronising mode to; 0 = MASTER, 1 = SLAVE, 2 = INDEP.
Sets the synchronising mode (0 = MASTER, 1 = SLAVE, 2 = INDEP).
LOLVL
Fc9-comp-macro.png LOLVL
Sets the amplitude-low-level to <nrf> Volts. (Lower limit: 5.000 V - Upper limit: -0.010 V).
Fc9-f32-icon.png - FLOAT LowLevel
Sets the amplitude-low-level in Volts(V) (-5.000 V - -0.010 V).
LRN
Fc9-comp-macro.png LRN
Intall data from a previous *LRN? command.
LRNRet
Fc9-comp-macro.png LRNRet
Returns the complete setup of the instrument as a binary data block
MOD
Fc9-comp-macro.png MOD
Sets modulation to; 0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM.
Fc9-u8-icon.png - BYTE Modulation
Sets modulation (0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM).
MODAMDEPTH
Fc9-comp-macro.png MODAMDEPTH
Sets AM waveform depth to <nrf> %. (Lower limit: 0% - Upper limit: 120%).
Sets AM waveform depth in percent (%) (0 - 120).
MODAMFREQ
Fc9-comp-macro.png MODAMFREQ
Sets AM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz).
Sets AM waveform frequency in Hertz(Hz) (1uHz - 20kHz).
MODAMSHAPE
Fc9-comp-macro.png MODAMSHAPE
Sets AM waveform shape to: 0 = SINE, 1 = SQUARE, 2 = RAMPUP, 3 = RAMPDN, 4 = TRIANG, 5 = NOISE, 6 = DC, 7 = SINC, 8 = EXPRISE, 9 = LOGRISE, 10 = ARB1, 11 = ARB2, 12 = ARB3, 13= ARB4.
Fc9-u8-icon.png - BYTE Shape
Sets AM waveform shape (1 = SINE, 2 = SQUARE, 3 = RAMPUP, 4 = RAMPDN, 5 = TRIANG, 6 = NOISE, 7 = DC, 8 = SINC, 9 = EXPRISE, 10 = LOGRISE, 11 = ARB1, 12 = ARB2, 13 = ARB3, 14= ARB4).
MODAMSRC
Fc9-comp-macro.png MODAMSRC
Sets AM waveform source to; 0 = INT, 1 = EXT.
Sets AM waveform source (0 = INT, 1 = EXT).
MODFMDEV
Fc9-comp-macro.png MODFMDEV
Sets FM waveform deviation to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 25MHz).
Fc9-f32-icon.png - FLOAT Deviation
Sets FM waveform deviation in Hertz(Hz) (1uHz - 25MHz).
MODFMFREQ
Fc9-comp-macro.png MODFMFREQ
Sets FM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz).
Sets FM waveform frequency in Hertz(Hz) (1uHz - 20kHz).
MODFMSHAPE
Fc9-comp-macro.png MODFMSHAPE
Sets FM waveform shape to: 0 = SINE, 1 = SQUARE, 2 = RAMPUP, 3 = RAMPDN, 4 = TRIANG, 5 = NOISE, 6 = DC, 7 = SINC, 8 = EXPRISE, 9 = LOGRISE, 10 = ARB1, 11 = ARB2, 12 = ARB3, 13= ARB4.
Sets FM waveform shape (1 = SINE, 2 = SQUARE, 3 = RAMPUP, 4 = RAMPDN, 5 = TRIANG, 6 = NOISE, 7 = DC, 8 = SINC, 9 = EXPRISE, 10 = LOGRISE, 11 = ARB1, 12 = ARB2, 13 = ARB3, 14= ARB4).
MODFMSRC
Fc9-comp-macro.png MODFMSRC
Sets FM waveform source to; 0 INT, 1 = EXT.
Sets FM waveform source (0 = INT, 1 = EXT).
MODFSKRATE
Fc9-comp-macro.png MODFSKRATE
Sets FSK rate to <nrf> Hz. (Lower limit: 2mHz - Upper limit: 100kHz).
Fc9-f32-icon.png - FLOAT Rate
Sets FSK rate in Hertz(Hz) (2mHz - 100kHz).
MODFSKSRC
Fc9-comp-macro.png MODFSKSRC
Sets FSK waveform source to; 0 = INT, 1 = EXT.
Sets FSK waveform source (0 = INT, 1 = EXT).
MODHOPFREQ
Fc9-comp-macro.png MODHOPFREQ
Sets HOP frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 50MHz).
Sets HOP frequency in Hertz(Hz) (1uHz - 50MHz).
MODPMDEV
Fc9-comp-macro.png MODPMDEV
Sets PM waveform deviation to <nrf> degrees. (Lower limit: -360° - Upper limit: 360°).
Sets PM waveform deviation in degrees (-360 - 360).
MODPMFREQ
Fc9-comp-macro.png MODPMFREQ
Sets PM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz).
MODPMSHAPE
Fc9-comp-macro.png MODPMSHAPE
Sets PM waveform shape to; 0 = SINE, 1 = SQUARE, 2 = RAMPUP, 3 = RAMPDN, 4 = TRIANG, 5 = NOISE, 6 = DC, 7 = SINC, 8 = EXPRISE, 9 = LOGRISE, 10 = ARB1, 11 = ARB2, 12 = ARB3, 13= ARB4.
Sets PM waveform shape (1 = SINE, 2 = SQUARE, 3 = RAMPUP, 4 = RAMPDN, 5 = TRIANG, 6 = NOISE, 7 = DC, 8 = SINC, 9 = EXPRISE, 10 = LOGRISE, 11 = ARB1, 12 = ARB2, 13 = ARB3, 14= ARB4).
MODPMSRC
Fc9-comp-macro.png MODPMSRC
Sets PM waveform source to; 0 INT, 1 = EXT.
Sets PM waveform source (0 = INT, 1 = EXT).
MODPOLFSK
Fc9-comp-macro.png MODPOLFSK
Sets FSK trigger slope to; 0 = POS, 1 = NEG.
Set FSK trigger slope (0 = POS, 1 = NEG).
MODPWMDEVSYM
Fc9-comp-macro.png MODPWMDEVSYM
Sets PWM deviation to <nrf> %. ?
Fc9-u8-icon.png - BYTE Deviation
Sets PWM waveform deviation in percent. (?)
MODPWMDEVWDT
Fc9-comp-macro.png MODPWMDEVWDT
Sets the PWM waveform deviation to <nrf> sec.
MODPWMFREQ
Fc9-comp-macro.png MODPWMFREQ
Sets PWM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz).
Sets PWM waveform frequency in Hertz(Hz) (1uHz - 20kHz).
MODPWMSHAPE
Fc9-comp-macro.png MODPWMSHAPE
Sets PWM waveform shape to; 0 = SINE, 1 = SQUARE, 2 = RAMPUP, 3 = RAMPDN, 4 = TRIANG, 5 = NOISE, 6 = DC, 7 = SINC, 8 = EXPRISE, 9 = LOGRISE, 10 = ARB1, 11 = ARB2, 12 = ARB3, 13= ARB4.
Sets PWM waveform shape (1 = SINE, 2 = SQUARE, 3 = RAMPUP, 4 = RAMPDN, 5 = TRIANG, 6 = NOISE, 7 = DC, 8 = SINC, 9 = EXPRISE, 10 = LOGRISE, 11 = ARB1, 12 = ARB2, 13 = ARB3, 14= ARB4).
MODPWMSRC
Fc9-comp-macro.png MODPWMSRC
Sets PWM waveform source to; 0 = INT, 1 = EXT.
Sets PWM waveform source (0 = INT, 1 = EXT).
MSTLOCK
Fc9-comp-macro.png MSTLOCK
Sends signal to SLAVE generator to get synchronised
MSTRELOCK
Fc9-comp-macro.png MSTRELOCK
Resynchronises the two generators in MASTER-SLAVE mode.
NOISADD
Fc9-comp-macro.png NOISADD
Select <ON> to add the noise to the output waveform and <OFF> to remove the noise from the output waveform. 0 = ON, 1 = OFF.
Fc9-bool-icon.png - BOOL Noise
Add/remove the noise to/from the output waveform (0 = ON, 1 = OFF).
NOISLVL
Fc9-comp-macro.png NOISLVL
Sets the output noise level to <nr1> %. (Lower limit: 0% - Upper limit: 50%)
Fc9-u8-icon.png - BYTE Percent
Sets the output noise level in percent. (0 - 50)
OPC
Fc9-comp-macro.png OPC
Sets the Operation Complete bit (bit 0) in the Standard Event Status Register. This will happen immediately the command is executed because of the sequential nature of all operations.
OPCRet
Fc9-comp-macro.png OPCRet
Query Operation Complete status. The response is always 1<rmt> and will be available immediately the command is executed because all commands are sequential.
OUTPUT
Fc9-comp-macro.png OUTPUT
Sets the output to; 0 = ON, 1 = OFF, 2 = NORMAL, 3 = INVERT.
Fc9-u8-icon.png - BYTE SetOutput
Set the output. (0 = ON, 1 = OFF, 2 = NORMAL, 3 = INVERT).
PER
Fc9-comp-macro.png PER
Sets the waveform period to <nrf> sec. (Lower limit: 20ns - Upper limit: 1Ms)
Fc9-f32-icon.png - FLOAT Period
Duration of the waveform period in seconds (20ns - 1Ms).
PRE
Fc9-comp-macro.png PRE
Sets the Parallel Port Enable Register to the value <nrf>.
Fc9-u8-icon.png - BYTE Status
Set register value 0-255
PRERet
Fc9-comp-macro.png PRERet
Returns the value in the Parallel Poll Enable Register in <nr1> numeric format. The syntax of the response is <nr1><rmt>.
PULSDLY
Fc9-comp-macro.png PULSDLY
Sets the waveform delay to <nrf> sec
PULSEDGE
Fc9-comp-macro.png PULSEDGE
Sets the pulse waveform edges (positive and negative edge) to <nrf> micro Sec. Value zero sets to the minimum value allowed (Lower limit: 5ns - Upper limit: 40us).
Fc9-f32-icon.png - FLOAT Edges
Sets the pulse waveform edges in micro seconds (5ns - 40us).
PULSFALL
Fc9-comp-macro.png PULSFALL
Sets the pulse waveform negative edge to <nrf> micro seconds. (Lower limit: 5ns - Upper limit: 99.9ns).
Fc9-f32-icon.png - FLOAT Fall
Sets the pulse waveform negative edge in micro seconds (5ns - 99.9ns).
PULSFREQ
Fc9-comp-macro.png PULSFREQ
Sets the pulse waveform frequency to <nrf> Hz (Lower limit: 1uHz - Upper limit: 50MHz).
Sets the pulse waveform frequency in Hertz(Hz) (1uHz - 50MHz).
PULSPER
Fc9-comp-macro.png PULSPER
Sets the pulse waveform period to <nrf> sec. (Lower limit: 20ns - Upper limit: 1Ms).
Duration of the pulse waveform period (20ns - 1Ms).
PULSRANGE
Fc9-comp-macro.png PULSRANGE
Sets PWM waveform source to <1>, <2> or <3>; 1 = 1, 2 = 2, 3 = 3.
Fc9-u8-icon.png - BYTE Range
Sets the pulse rise and fall range. (1, 2 or 3)
PULSRISE
Fc9-comp-macro.png PULSRISE
Fc9-f32-icon.png - FLOAT Rise
Sets the pulse waveform positive edge in micro seconds (5ns - 99.9ns).
PULSSYMM
Fc9-comp-macro.png PULSSYMM
Sets the pulse waveform symmetry to <nrf> %. (Lower limit: 0 - Upper limit: 100)
Fc9-f32-icon.png - FLOAT Symmetry
Sets the pulse waveform symmetry in percent. (0 - 100)
PULSWID
Fc9-comp-macro.png PULSWID
Sets the pulse waveform width to <nrf> sec. (Lower limit: 20ns - Upper limit: 1Ms).
Sets the pulse waveform width in seconds (20ns - 1Ms).
QERRet
Fc9-comp-macro.png QERRet
Query and clear error register
RCL
Fc9-comp-macro.png RCL
Recalls the instrument setup contained in store <nrf>.
Fc9-u8-icon.png - BYTE StoreLocation
Memory location (0-9)
RMPSYMM
Fc9-comp-macro.png RMPSYMM
Sets the ramp waveform symmetry to <nrf> %. (Lower limit: 0 - Upper limit: 100)
Sets the ramp waveform symmetry in percent (0 - 100).
RST
Fc9-comp-macro.png RST
Resets the instrument parameters to their default values.
SAV
Fc9-comp-macro.png SAV
Saves the complete instrument setup to the setup-file named <nrf>
Memory location of register (0-9)
SLVRST
Fc9-comp-macro.png SLVRST
Sets the SLAVE generator ready to be synchronised
SQRSYMM
Fc9-comp-macro.png SQRSYMM
Sets the square waveform symmetry to <nrf> %. (Lower limit: 20 - Upper limit: 80)
Sets the square waveform symmetry in percent (20 - 80).
SRE
Fc9-comp-macro.png SRE
Set the Service Request Enable Register to <nrf>.
SRERet
Fc9-comp-macro.png SRERet
Returns the value of the Service Request Enable Register in <nr1> numeric format.
STBRet
Fc9-comp-macro.png STBRet
Returns the value of the Status Byte Register in <nr1> numeric format.
SWP
Fc9-comp-macro.png SWP
Sets the sweep to <ON> or <OFF>. 0 = ON, 1 = OFF.
Fc9-bool-icon.png - BOOL Sweep
Enable or disable the sweep (0 = ON, 1 = OFF).
SWPBEGFREQ
Fc9-comp-macro.png SWPBEGFREQ
Sets the sweep start frequency to <nrf> Hz (Lower limit: 1uHz - Upper limit: 100kHz)
Sets the sweep start frequency in Hertz(Hz) (1uHz - 100kHz).
SWPCNTFREQ
Fc9-comp-macro.png SWPCNTFREQ
Sets the sweep centre frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 50MHz).
Sets the sweep centre frequency in Hertz(Hz) (1uHz - 50MHz).
SWPENDFREQ
Fc9-comp-macro.png SWPENDFREQ
Sets the sweep centre frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 50MHz.)
Set the sweep end frequency in Hertz(Hz) (1uHz - 50MHz).
SWPMKR
Fc9-comp-macro.png SWPMKR
Sets the sweep marker to <ON> or <OFF>. 0 = ON, 1 = OFF.
Fc9-bool-icon.png - BOOL Marker
Enable or disable the sweep marker (0 = ON, 1 = OFF).
SWPMKRFREQ
Fc9-comp-macro.png SWPMKRFREQ
Sets the sweep marker to <nrf> Hz. (Lower limit: 10kHz - Upper limit: 100kHz).
Set the sweep marker in Hertz(Hz) (10kHz - 100kHz).
SWPMODE
Fc9-comp-macro.png SWPMODE
Sets the sweep mode to <CONT> or <TRIG>. 0 = CONT, 1 = TRIG.
Fc9-bool-icon.png - BOOL Mode
Set the sweep mode (0 = CONT, 1 = TRIG).
SWPSPNFREQ
Fc9-comp-macro.png SWPSPNFREQ
Sets the sweep frequency span to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 50.25kHz).
Set the sweep frequency span in Hertz(Hz) (1uHz - 50.25kHz).
SWPTIME
Fc9-comp-macro.png SWPTIME
Sets the sweep time to <nrf> seconds
Set the sweep time in seconds.
SWPTRGPER
Fc9-comp-macro.png SWPTRGPER
Sets the sweep trigger period to <nrf> seconds
Set the sweep trigger period in seconds.
SWPTRGPOL
Fc9-comp-macro.png SWPTRGPOL
Sets the sweep trigger slope to; 0 = POS, 1 = NEG.
Set the sweep trigger slope (0 = POS, 1 = NEG).
SWPTRGSRC
Fc9-comp-macro.png SWPTRGSRC
Sets the sweep trigger source to; 0 = INT, 1 = EXT, 2 = MAN.
Set the sweep trigger source (0 = INT, 1 = EXT, 2 = MAN).
SWPTYPE
Fc9-comp-macro.png SWPTYPE
Sets the sweep type to; 0 = LINUP, 1 = LINDN, 2 = LINUPDN, 3 = LINDNUP, 4 = LOGUP, 5 = LOGDN, 6 = LOGUPDN, 7 = LOGDNUP.
Fc9-u8-icon.png - BYTE Type
Set the sweep type (0 = LINUP, 1 = LINDN, 2 = LINUPDN, 3 = LINDNUP, 4 = LOGUP, 5 = LOGDN, 6 = LOGUPDN, 7 = LOGDNUP).
SYNCOUT
Fc9-comp-macro.png SYNCOUT
Sets the sync output to; 0 = ON, 1 = OFF.
Fc9-bool-icon.png - BOOL Sync
Enable/disable sync output (0 = ON, 1 = OFF).
SYNCTYPE
Fc9-comp-macro.png SYNCTYPE
Sets the sync type to; 0 = AUTO, 1 = CARRIER, 2 = MODULATION, 3 = SWEEP, 4 = BURST, 5 = TRIGGER.
Set the sync type (0 = AUTO, 1 = CARRIER, 2 = MODULATION, 3 = SWEEP, 4 = BURST, 5 = TRIGGER).
TRG
Fc9-comp-macro.png TRG
This command is the same as pressing the TRIGGER key.
TSTRet
Fc9-comp-macro.png TSTRet
The generator has no self test capability and the response is always 0 <rmt>.
WAI
Fc9-comp-macro.png WAI
Wait for Operation Complete true. As all commands are fully executed before the next is started this command takes no additional action.
WAVE
Fc9-comp-macro.png WAVE
Sets the waveform type. 0 = SINE, 1 = SQUARE, 2 = RAMP, 3 = TRIANG, 4 = PULSE, 5 = NOISE, 6 = ARB
Fc9-u8-icon.png - BYTE WaveType
0 = SINE, 1 = SQUARE, 2 = RAMP, 3 = TRIANG, 4 = PULSE, 5 = NOISE, 6 = ARB.
WAVELVL
Fc9-comp-macro.png WAVELVL
Sets the output waveform level to <nr1> %. (Lower limit: 50 - Upper limit: 100)
Fc9-f32-icon.png - FLOAT Percent
Sets the output waveform level in percent (50 - 100).
ZLOAD
Fc9-comp-macro.png ZLOAD
sets the output load, which the generator is to assume for amplitude and dc offset entries, to; 0 = OPEN or 1 - 10,000
Fc9-s16-icon.png - INT Output
Sets the output load for amplitude and dc offset entires (0 = OPEN or 1 -10,000).
Fc9-type-16-icon.png COM Port
Selects which port to communicate with, only lists ports which are currently available.
Fc9-type-7-icon.png Refresh COM Ports
When set to yes the COM port list is rescanned for newly connected or available ports. Note that refreshing the ports list may take a few seconds depending on the number of connected ports.
