Component: SPI Master (EB013) (E-blocks 1)
(Redirected from Component: ID 4627d2fb b41e 44cf b125 e8511e5ebaa4)
Version | 2.0 |
Category | E-blocks 1 |
SPI Master component
Low level routines for controlling or interacting with an SPI interface. SPI or Serial Peripheral Interface is a bus used for board level communications between devices. A target microcontroller will usually have at least one hardware SPI peripheral built in. If the hardware SPI pins are in use or more SPI channels are required then there is also a software mode available. Has additional functions to work with the E-blocks EB013 SPI hardware.
Please click here to download the component source project: FC_Comp_Source_SPI_Legacy.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_SPI_Legacy.fcfx
DACSendChar
DACSendChar | |
Send a byte to the digital to analogue converter (DAC) on the EB013 SPI E-block. | |
- BYTE | Data |
Data byte to output using the DAC | |
- VOID | Return |
DisableFram
DisableFram | |
Disable the SPI RAM chip on the EB013 SPI E-block. | |
- VOID | Return |
EnableFram
EnableFram | |
Enable the SPI RAM chip on the EB013 SPI E-block. | |
- VOID | Return |
FramOutput
FramOutput | |
Send a value to the RAM on the EB013 SPI E-block. | |
- BYTE | Char |
- BYTE | Return |
GetChar
GetChar | |
General purpose SPI get byte macro | |
- BYTE | Return |
GetString
GetString | |
Attempts to read a string of bytes from the SPI bus. | |
- BYTE | NumBytes |
- BYTE | Ch |
- STRING | Return |
Initialise | |
Activates the SPI peripheral and claims control over the I/O pins. | |
- VOID | Return |
NVMGetChar
NVMGetChar | |
Reads a byte from the non-volatile memory device on the EB013 SPI E-block. | |
- ULONG | Address |
NVM Address to read data from | |
- BYTE | Return |
NVMSendChar
SendChar
SendChar | |
General purpose SPI send byte macro | |
- BYTE | Char |
- VOID | Return |
SendString
SendString | |
Sends a string of bytes to the SPI bus | |
- STRING | Str |
- VOID | Return |
UnInitialise
UnInitialise | |
Deactivates the SPI peripheral leaving the I/O pins in a state where they can be used for general purpose I/O. | |
- VOID | Return |
