Component: GLCD (SSD1305) (SSD1305) (Graphical Monochrome)
Version 1.8
Category Graphical Monochrome
GLCD (SSD1305) component
Graphical display component based on the SSD1305 monochrome graphical controller IC.
BPlot
Fc9-comp-macro.png BPlot
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
ClearDisplay
DrawCircle
Fc9-comp-macro.png DrawCircle
Fc9-u8-icon.png - BYTE Solid
DrawEllipse
DrawLine
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
DrawRectangle
Fc9-comp-macro.png Initialise
Plot
Fc9-comp-macro.png Plot
Print
Fc9-comp-macro.png Print
Fc9-u8-icon.png - BYTE Font
Fc9-s16-icon.png - INT Number
ReadFontStat
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
ReadFontWidth
SetBackgroundColour
Fc9-u8-icon.png - BYTE PixelColour
0=White, 1=Black
SetDisplayOrientation
SetFontScaler
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
SetForegroundColour
0=White, 1=Black
Fc9-conn-icon.png Dimensions
Fc9-type-21-icon.png H Offset
Offset from the edge of the display, default 0.
Fc9-conn-icon.png Colour
Fc9-conn-icon.png Bit Depth
Fc9-type-14-icon.png Colour Bit Depth
Fc9-type-5-icon.png Chip Select (CS)
Chip select pin connection
Fc9-type-5-icon.png Read / Write (R/W)
Fc9-type-5-icon.png Reg Select (RS)
Fc9-type-5-icon.png Data (SD)
Fc9-type-5-icon.png Serial Clock (SCK)
Reset pin connection
Fc9-type-5-icon.png Reset (RST)
Fc9-conn-icon.png Fonts
Fc9-conn-icon.png Font 0
Fc9-conn-icon.png Simulation
Fc9-type-11-icon.png User Label Text
Text to display
Fc9-type-15-icon.png Component Label Scale
Fc9-type-16-icon.png Physical Orientation
Please click here to download the component source project: FC_Comp_Source_GLCD_SSD1305.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_SSD1305.fcfx
