Component: Thermocouple (MCP960X) (Environmental)
(Redirected from Component: ID 60de8264 7faf 4f77 904e 69bb19909ba8)
Version | 1.1 |
Category | Environmental |
Thermocouple (MCP960X) component
Component to interface the MCP960X IC from Microchip. Uses a standard 2-wire I2C interface to connect to the IC and collect the temperature. IC available in different versions to suit different thermocouple types.
Please click here to download the component source project: FC_Comp_Source_ThermocoupleMCP960X.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ThermocoupleMCP960X.fcfx
Here is a basic example to display both the thermocouple temperature and IC surface temperature.
Sim Demo
Initialise | |
Configures the I2C bus ready for communications. | |
- VOID | Return |
ReadRawDataADC
ReadRawDataADC | |
Returns the thermocouple temperature from the last sample as an integer value in Degrees C. | |
- LONG | Return |
ReadReference_Float
ReadReference_Float | |
Returns the reference (IC die) temperature from the last sample as a floating point. Use Sample first, which samples both reference & themocouple temperatures. | |
- FLOAT | Return |
ReadReference_Int
ReadReference_Int | |
Returns the Reference (IC die) temperature from the last sample as an integer value. Use Sample first, which samples both reference & themocouple temperatures. | |
- INT | Return |
ReadThermocouple_Float
ReadThermocouple_Float | |
Returns the thermocouple temperature from the last sample as a floating point value. Use Sample first, which samples both reference & themocouple temperatures. | |
- FLOAT | Return |
ReadThermocouple_Int
ReadThermocouple_Int | |
Returns the thermocouple temperature from the last sample as an integer value. Use Sample first, which samples both reference & themocouple temperatures. | |
- INT | Return |
Sample
