Component: Output PWM (DSP Outputs)
Version 1.2
Category DSP Outputs
Output PWM component
Allows the values from a buffer to be passed directly to an internal PWM output.
Please click here to download the component source project: FC_Comp_Source_DSP_PWM.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_PWM.fcfx
ControlPWM
Fc9-comp-macro.png ControlPWM
Enable or disable the PWM output, Disabled by default.
Fc9-bool-icon.png - BOOL State
0=Disable, 1=Enable
OutputPWM
Fc9-comp-macro.png OutputPWM
Outputs a single value from the input buffer appropriatley scaled to suit the PWM.
OutputPWMArray
Fc9-comp-macro.png OutputPWMArray
Outputs an array of values from the input buffer appropriatley scaled to suit the PWM.
Fc9-u16-icon.png - UINT Delay
Delay in microseconds between outputting each sample.
Fc9-type-16-icon.png Connect To
Fc9-conn-icon.png PWM
Fc9-type-16-icon.png Channel
PWM Channel selector
Fc9-type-16-icon.png Alt Pin Enable
Alternative Pin Enable (if available on target device)
Fc9-type-5-icon.png Port
Fc9-type-14-icon.png Period Register
PWM Period Register value
Fc9-type-16-icon.png Prescaler Divide
Prescaler Divider value
Fc9-type-16-icon.png PWM Timer
Timer associated with PWM to drive the output. Warning - All PWM channels linked to the same timer will share the same period and prescaler settings.
Fc9-type-15-icon.png Period (uS)
Fc9-type-15-icon.png Frequency (KHz)
