Component: UART Software (Timer) (Comms: Interface)
(Redirected from Component: ID 743ea495 34e7 47ee bd79 3bfdc067b01c)
Jump to navigationJump to searchAuthor | MatrixTSL |
Version | 1.0 |
Category | Comms: Interface |
UART Software (Timer) component
Creates a reliable software UART that can be driven using a timer interrupt setup by the user. The timer interrupt must be interrupting at the required baud rate. e.g 9600Hz.
Please click here to download the component source project: FC_Comp_Source_UART_Software_Timer.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_UART_Software_Timer.fcfx
Simple example showing how to enable a timer interrupt at the desired baud rate then receive a string. If anything is received then it will be echoed back out and displayed on a LCD
CheckBuffer
CheckBuffer | |
Returns the number of values in the transmit or receive buffer | |
- BOOL | Buffer |
0=Transmit / 1=Receive | |
- UINT | Return |
Initialise | |
Initialises the UART component pins ready to send and receive data | |
- VOID | Return |
ReceiveArray
ReceiveArray | |
Gets an array of values from the receive buffer. Returns number of values received. | |
- UINT | Values |
- UINT | NumValues |
- UINT | Timeout |
Time in milliseconds to wait for data | |
- UINT | Return |
ReceiveString
ReceiveString | |
Gets a string from the receive buffer | |
- UINT | MaxChars |
- UINT | Timeout |
- STRING | Return |
ReceiveValue
ReceiveValue | |
Gets a single value from the receive buffer | |
- UINT | Timeout |
- UINT | Return |
SendArray
SendArray | |
Sends an array of values to the transmit buffer | |
- UINT | Values |
- VOID | Return |
SendString
SendString | |
Sends an string to the transmit buffer | |
- STRING | Data |
- VOID | Return |
SendValue
SendValue | |
Sends a single value to the transmit buffer | |
- UINT | Value |
- VOID | Return |
UART_Timer_Process
UART_Timer_Process | |
Called as part of a timer interrupt at the specific UART baud rate. | |
- VOID | Return |
