Component: Robot Arm AllCode API (Misc)
(Redirected from Component: ID 83c10dbf a8d2 42d0 8be5 60adbe2d49b1)
Version | 1.0 |
Category | Misc |
- 1 Robot Arm AllCode API component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 Beep
- 5.2 GetAPIVersion
- 5.3 GotoPosition
- 5.4 GripperClose
- 5.5 GripperOpen
- 5.6 KineGetXYZ
- 5.7 KineSetXYZ
- 5.8 LCDClear
- 5.9 LCDClearLine
- 5.10 LCDCursor
- 5.11 LCDPrintNum
- 5.12 LCDPrintStr
- 5.13 LCDVerbose
- 5.14 LEDOff
- 5.15 LEDOn
- 5.16 LEDWrite
- 5.17 MotorsMoving
- 5.18 Park
- 5.19 ReadColour
- 5.20 ReadColourChannel
- 5.21 ReadPressure
- 5.22 ReadSwitch
- 5.23 SetAllServos
- 5.24 SetServo
- 5.25 SetTrim
- 5.26 StoreCoords
- 5.27 StorePosition
- 6 Property reference
Matrix 5-axis Robot Arm with Gripper. Compatible with the Matrix Robot ARM Training Curriculum and Hardware. Features gripper pressure sensor, light sensor, colour sensor, Potentiometer, Magnetic sensor.
Please click here to download the component source project: FC_Comp_Source_RA_API_Component_Source.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_RA_API_Component_Source.fcsx
Beep
Beep | |
Allows the beeper to output a warning | |
- BYTE | Iterations |
Number of times to repeat | |
- UINT | OnDelay |
Delay in ms | |
- UINT | OffDelay |
Delay in ms | |
- BYTE | Return |
GetAPIVersion
GetAPIVersion | |
Gets the API version of the Robot ARM Firmware | |
- BYTE | Return |
GotoPosition
GotoPosition | |
Recalls a previously saved position for the ARMs 5 axis. | |
- BYTE | Index |
Save Index - Range 0-29 | |
- VOID | Return |
GripperClose
GripperOpen
GripperOpen | |
Fully opens the gripper at the end of the arm ready to pick something up. | |
- VOID | Return |
KineGetXYZ
KineGetXYZ | |
Calculates the current XYZ position from the current servo position coordinates | |
- BYTE | Index |
Range 0-2 : 0=X, 1=Y, 2=Z | |
- INT | Return |
KineSetXYZ
KineSetXYZ | |
Sets the XYZ position and calculates the various servo motor angles required. Returns 0=Impossible, 1=InPosition | |
- INT | X |
- INT | Y |
- INT | Z |
- BYTE | Return |
LCDClear
LCDClear | |
Clears the entire contents of the display. | |
- VOID | Return |
LCDClearLine
LCDCursor
LCDPrintNum
LCDPrintNum | |
Will allow you to print a number. This is limited to a signed-INT, -32768 to 32767 | |
- INT | Number |
Enter the number or variable to print to the LCD | |
- VOID | Return |
LCDPrintStr
LCDPrintStr | |
Breaks down a string of text and sends it to the LCD via the private RawSend(byte, mask) macro | |
- STRING | PrintString |
Enter the text or variable to print to the LCD | |
- VOID | Return |
LCDVerbose
LCDVerbose | |
Controls if the LCD is in user mode or verbose API mode, | |
- BYTE | Mode |
0=User Mode, 1=API Verbose Mode | |
- VOID | Return |
LEDOff
LEDOff | |
Switches off a single LED, LA0-LA7 | |
- BYTE | Index |
0=LA0, 1=LA1, 2=LA2, 3=LA3, 4=LA4, 5=LA5, 6=LA6, 7=LA7 | |
- VOID | Return |
LEDOn
LEDOn | |
Switches on a single LED, LA0-LA7 | |
- BYTE | Index |
- VOID | Return |
LEDWrite
LEDWrite | |
Allows a value to be sent to control all eight LEDs LA0-LA7 at once | |
- BYTE | Value |
(0-63) 0b000000 | |
- VOID | Return |
MotorsMoving
MotorsMoving | |
Checks to see if any of the motors are still moving. | |
- BYTE | Return |
Park
Park | |
Parks the Robot ARM and switches off the servo motors | |
- VOID | Return |
ReadColour
ReadColourChannel
ReadColourChannel | |
Reads a single colour channel from the value returned from the ReadColour macro. | |
- BYTE | Index |
0=Red, 1=Green, 2=Blue | |
- UINT | Colour |
- BYTE | Return |
ReadPressure
ReadPressure | |
Read the value of the pressure sensor on the ARM gripper. Returns the value as a byte | |
- BYTE | Return |
ReadSwitch
ReadSwitch | |
Read the value of a single switch. Returns the value as a byte | |
- BYTE | index |
0=SA0, 1=SA1, 2=SA2, 3=SA3, 4=SA4, 5=SA5, 6=SA6, 7=SA7 | |
- BYTE | Return |
SetAllServos
SetServo
SetTrim
SetTrim | |
Allows minor adjustment on the 5 axis servo motors | |
- BYTE | Index |
Motor Index Range 0-4 | |
- BYTE | Trim |
Amount of Trim Range 0-255, Default Value 128 | |
- VOID | Return |
StoreCoords
StorePosition
StorePosition | |
Stores the current position of the ARMs 5 axis. | |
- BYTE | Index |
- VOID | Return |
Properties | |
Connections | |
Operating Mode | |
Mode | |
