Component: TCP/IP (ENC28J60) (Comms: Networking)
(Redirected from Component: ID 8aab4b54 a912 449c b11a 7c1a5db8d591)
Version | 2.2 |
Category | Comms: Networking |
- 1 TCP/IP (ENC28J60) component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 CheckArpPacketIsMyreplyArp
- 5.2 CheckForARP
- 5.3 CheckForIp
- 5.4 CheckForPing
- 5.5 CheckForTCPPort
- 5.6 CheckForTCPType
- 5.7 ClientSendPacket
- 5.8 ControlLEDs
- 5.9 FillTcpArray
- 5.10 FillTcpData
- 5.11 GetDataLength
- 5.12 GetModuleRevision
- 5.13 GetSendersMAC
- 5.14 GetTcpDataPointer
- 5.15 Initialise
- 5.16 InitialiseDataLengthInfo
- 5.17 MakeArpAnswerFromRequest
- 5.18 MakeArpRequest
- 5.19 MakeEchoReplyFromRequest
- 5.20 MakeTcpAckFromAny
- 5.21 MakeTcpAckWithData
- 5.22 MakeTcpSynackFromSyn
- 5.23 PacketReceive
- 5.24 PacketSend
- 5.25 ReadArrayFromBuffer
- 5.26 ReadRegister
- 5.27 ReadStringFromBuffer
- 5.28 SetMyIPAddress
- 5.29 SetMyMACAddress
- 5.30 WriteRegister
- 6 Property reference
A set of routines used to control a ENC28J60 TCP/IP Module. Required connections VCC, Reset, GND, SCK, MISO, MOSI, CS. Leave these pins disconnected CLKOUT, ENC_WOL, ENC_INT
Please click here to download the component source project: FC_Comp_Source_TCPIP_ENC28J60.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TCPIP_ENC28J60.fcfx
Here is a simple example to help get started with the ENC28J60 module.
The example program creates a web page server on the network and will also respond to ping requests.
The HTML to drive the web pages is included in the flowchart near the bottom of the main program loop. ENC28J60 Example
CheckArpPacketIsMyreplyArp | |
- BYTE | Return |
CheckForARP
CheckForARP | |
Checks to see if the received data is an ARP request with my IP address. | |
- UINT | Length |
- BYTE | Return |
CheckForIp
CheckForIp | |
Checks to see if the received data is an IP request with my IP address. | |
- UINT | Length |
- BYTE | Return |
CheckForPing
CheckForPing | |
Checks to see if the received data is a Ping request | |
- BYTE | Return |
CheckForTCPPort
CheckForTCPPort | |
Checks to see if the received data is requesting the server port | |
- UINT | Port |
- BYTE | Return |
CheckForTCPType
CheckForTCPType | |
Checks to what kind of TCP type the received data is requesting. Returns a bit field specifying the type of request. 0x01 = Ack Requires, 0x02 = Synchronise 0x10 = Ack | |
- BYTE | Return |
ClientSendPacket
ClientSendPacket | |
- UINT | DestPort |
- UINT | SourcePort |
- BYTE | Flags |
- BYTE | MaxSegmentSize |
- BYTE | ClearSeqAck |
- UINT | NextAckNum |
- UINT | DataLength |
- BYTE | DestMac |
- BYTE | DestIp |
- VOID | Return |
ControlLEDs
ControlLEDs | |
Allows both the LEDs on the Ethernet socket to be controlled. Useful for checking if the SPI communications are functioning correctly. | |
- BYTE | Mode |
0=Off, 1=On, 2=Auto | |
- VOID | Return |
FillTcpArray
FillTcpArray | |
- UINT | Position |
- UINT | Count |
- BYTE | Data |
- VOID | Return |
FillTcpData
FillTcpData | |
- UINT | Position |
- STRING | Data |
- UINT | Return |
GetDataLength
GetDataLength | |
Returns the number of received data bytes after the headers | |
- UINT | Return |
GetModuleRevision
GetModuleRevision | |
Requets the module revision number and returns the value supplied by the module's firmware. | |
- BYTE | Return |
GetSendersMAC
GetSendersMAC | |
Gets the MAC address from locations 6-11 of the IP Header | |
- BYTE | MAC |
6-byte Array to store the MAC address | |
- VOID | Return |
GetTcpDataPointer
GetTcpDataPointer | |
- UINT | Return |
InitialiseDataLengthInfo | |
Initialises the data pointers to allow us to craft a response containing data | |
- VOID | Return |
MakeArpAnswerFromRequest | |
- VOID | Return |
MakeArpRequest
MakeArpRequest | |
- BYTE | ServerIP |
- VOID | Return |
MakeEchoReplyFromRequest | |
- UINT | Length |
- VOID | Return |
MakeTcpAckFromAny
MakeTcpAckFromAny | |
- UINT | Port |
- VOID | Return |
MakeTcpAckWithData
MakeTcpAckWithData | |
- VOID | Return |
MakeTcpSynackFromSyn | |
- UINT | Port |
- VOID | Return |
PacketReceive
PacketReceive | |
Attempts to receive a data packet from the ENC28J60 module. Returns the number of bytes received. | |
- UINT | Return |
PacketSend
PacketSend | |
Attempts to transmit a data packet to the ENC28J60 module. | |
- UINT | Length |
- VOID | Return |
ReadArrayFromBuffer
ReadRegister
ReadRegister | |
Reads the value from a single register onboard the ENC28J60 module. | |
- BYTE | Address |
- BYTE | Return |
SetMyIPAddress
SetMyMACAddress
WriteRegister
WriteRegister | |
Writes a value to a single register onboard the ENC28J60 module. | |
- BYTE | Address |
- BYTE | Data |
- VOID | Return |
