Component: Thermistor (Environmental)
(Redirected from Component: ID 93ab1895 66cf 4fd8 a04f 79f09acc19e6)
Version | 1.1 |
Category | Environmental |
Thermistor component
A generic thermistor component that can be used to simulate and create code for any thermistor with a known temperature/resistance curve. Thermistor is connected in a simple potential divider circuit - thermistor between ADC input and 0V, and a fixed resistor between ADC and the positive supply. Default calibration is for the EBM003 module.
Please click here to download the component source project: FC_Comp_Source_Thermistor.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Thermistor.fcfx
CalculateTemperature
CalculateTemperature | |
Converts the input ADC value and returns the Temperature in tenths of degree C | |
- UINT | ADCValue |
ADC Reading to be converted | |
- INT | Return |
GetADCValue
GetADCValue | |
Returns the Raw ADC value from the Analogue Channel | |
- UINT | Return |
GetIntegerTemperature
GetIntegerTemperature | |
Reads the ADC input and returns the calculated Temperature as Integer degrees C | |
- INT | Return |
GetRealTemperature
GetRealTemperature | |
Reads the ADC input and Returns the calculated Temperature as Float value in degrees C | |
- FLOAT | Return |
SetChannel
SetChannel | |
Set the ADC Channel | |
- INT | ChannelID |
- VOID | Return |
SetMinMax
SetMinMax | |
Set the minimum and maximum temperature values that can be shown and set on the thermometer readout. | |
- FLOAT | Min |
Minimum Value | |
- FLOAT | Max |
Maximum Value | |
- VOID | Return |
SetTemperature
