Component: GLCD (SSD1306) Buffered (SSD1306) (Graphical Monochrome)
Version 1.6
Category Graphical Monochrome
GLCD (SSD1306) Buffered component
Graphical display component based on the SSD1306 monochrome graphical controller IC. Functions without the use of a read pin by hosting the 1K of graphical memory using the microcontroller's RAM memory.
BPlot
Fc9-comp-macro.png BPlot
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
ClearDisplay
ControlContrast
Fc9-comp-macro.png ControlContrast
Sets the display contrast from 0 to 255.
Fc9-u8-icon.png - BYTE Contrast
Range 0 - 255, Default 207
ControlDisplay
Fc9-comp-macro.png ControlDisplay
Allows the display to be switched on and off
Fc9-u8-icon.png - BYTE Control
0=Off, 1=On
DrawCircle
Fc9-comp-macro.png DrawCircle
Fc9-u8-icon.png - BYTE Solid
DrawEllipse
DrawLine
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
DrawRectangle
Fc9-comp-macro.png Initialise
InvertDisplay
Fc9-comp-macro.png InvertDisplay
Plot
Fc9-comp-macro.png Plot
Print
Fc9-comp-macro.png Print
Fc9-u8-icon.png - BYTE Font
Fc9-s16-icon.png - INT Number
ReadFontStat
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
ReadFontWidth
SendCommand
Fc9-comp-macro.png SendCommand
Fc9-u8-icon.png - BYTE Command
SetBackgroundColour
Fc9-u8-icon.png - BYTE PixelColour
0=White, 1=Black
SetDisplayOrientation
SetFontScaler
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
SetForegroundColour
0=White, 1=Black
Fc9-conn-icon.png Dimensions
Fc9-type-7-icon.png Interlaced
Fc9-type-21-icon.png Offset X
Fc9-type-21-icon.png Offset Y
Fc9-conn-icon.png Colour
Fc9-conn-icon.png Bit Depth
Fc9-type-14-icon.png Colour Bit Depth
Fc9-type-5-icon.png Chip Select (CS)
Chip select pin connection
Fc9-type-5-icon.png Reg Select (RS)
Fc9-type-5-icon.png Data (SD)
Fc9-type-5-icon.png Serial Clock (SCK)
Reset pin connection
Fc9-type-5-icon.png Reset (RST)
Fc9-conn-icon.png Fonts
Fc9-conn-icon.png Font 0
Fc9-conn-icon.png Simulation Mode
Fc9-type-16-icon.png Physical Orientation
Please click here to download the component source project: FC_Comp_Source_GLCD_SSD1306_buffered.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_SSD1306_buffered.fcfx
