Component: LCD (Generic, 20x4) (Alphanumeric)
(Redirected from Component: ID a2b40602 5421 4e2f ba82 96db1be51d69)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.1 |
Category | Alphanumeric |
LCD (Generic, 20x4) component
LCD based on the standard 4 x 20 character unit.
Please click here to download the component source project: FC_Comp_Source_LCD_4X20.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LCD_4X20.fcfx
For the LCDs to work with the Flowcode LCD component they need to be connected up in 4-bit data mode.
The 4 data signals actually go to the upper data nibble on the LCD as shown below.
Displaying a numeric value
The LCD will retain the contents of the display, for high speed data we only want to have to write to the portion of the display that can change. LCD Demo
Clear
Clear | |
Clears the entire contents of the display. | |
- VOID | Return |
ClearLine
Command
Cursor
PrintAscii
PrintAscii | |
Takes the ascii value for a character and prints the character | |
- BYTE | character |
Holds an ascii value. | |
- VOID | Return |
PrintFloat
PrintFormattedNumber
PrintNumber | |
Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767 | |
- INT | Number |
Enter the number or variable to print to the LCD | |
- VOID | Return |
PrintString
PrintString | |
Breaks down a string of text and sends it to the LCD via the private RawSend(byte, mask) macro | |
- STRING | Text |
Enter the text or variable to print to the LCD | |
- VOID | Return |
RAMWrite
RawSend
RawSend | |
Sends data to the LCD display | |
- BYTE | data |
The data byte to send to the LCD | |
- BOOL | type |
A boolean to indicate command type: true to write data, false to write a command | |
- VOID | Return |
RemapCharacter
ScrollDisplay
ScrollDisplay | |
Scrolls the display left or right by a number of given positions. | |
- BYTE | Position |
Holds the number of positions to shift the display | |
- BYTE | Direction |
0 = left, 1 = right | |
- VOID | Return |
Start
Start | |
Startup routine required by the hardware device. Automatically clears the display after initialising. | |
- VOID | Return |
