Component: UART SCADA (CAL) (Misc)
(Redirected from Component: ID a7c1210d 3637 4a18 a6b3 9414ee73b179)
Version | 2.1 |
Category | Misc |
UART SCADA component
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips. A low level implementation giving direct access to the UART peripheral. Includes simulation functionality to commmunicate via a COM port or an Injector component. Also includes timestamped logging via the console and Data Recorder trace monitoring support.
Please click here to download the component source project: FC_Comp_Source_UART_SCADA.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_UART_SCADA.fcfx
GetConsoleHandle
GetConsoleHandle | |
- HANDLE | Return |
Init
Init | |
Initialize the component with the specified properties | |
- VOID | Return |
Receive
Receive | |
Receive a Character | |
- UINT | Timeout |
Period to wait for the character to be received | |
- INT | Return |
ReceiveByteArray
ReceiveString
ScanForDeviceID
ScanForDeviceID | |
Checks to see if a device VID/PID string is present and returns the COM port number. Returns 0 if device not found. | |
- STRING | HWID |
Example: "VID_12BF&PID_0101" | |
- BYTE | Return |
Send
Send | |
Send the Character | |
- UINT | Char |
The Character to send | |
- VOID | Return |
SendByteArray
SendByteArray | |
Transmits an array of bytes via the UART peripheral | |
- BYTE | Data |
Data to transmit | |
- UINT | NumBytes |
Number of bytes to send from the array | |
- VOID | Return |
SendString
SendString | |
Transmits a string of bytes via the UART peripheral | |
- STRING | Data |
Data String to transmit | |
- VOID | Return |
Uninit
Uninit | |
Un-initialize the UART and release the resources | |
- VOID | Return |
