Component: LED (SMD, PCB) ()
Version 1.1
Category
LED (SMD, PCB) component
Surface mount LED in standard PLCC2 package. Colour can be set friom component properties.
Please click here to download the component source project: FC_Comp_Source_led_plcc2.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_led_plcc2.fcfx
Fc9-type-5-icon.png Connection
Pin to which the LED is connected.
Fc9-type-16-icon.png Polarity
Active High: Pin true -> On color, Pin false -> Off color. Active Low: Pin true -> Off color, Pin false -> On color.
Fc9-conn-icon.png Simulation
Fc9-type-1-icon.png Color
Color to use when the LED is turned on. When turned off, uses a much darker shade of the same hue.
Fc9-conn-icon.png Label
Fc9-type-16-icon.png Show
Decide what labels to show... None - no labels are displayed Name - shows each component's name Property - shows a particular property of each component (see 'property' below.
Fc9-type-10-icon.png Property
Show a particular property of each object. If a port or pin property is chosen, the label can be abbreviated to remove the '$PORT' text.
Color of the labels text.
Fc9-type-15-icon.png Scale
Sets the basic size (text height) of the labels.
Fc9-type-7-icon.png Follow Zoom
Whether labels get bigger and smaller when the panel is zoomed in and out.
Fc9-type-16-icon.png Position
Position of the label relative to the component
