Component: Switch (BL0145) (E-blocks 2)
(Redirected from Component: ID b3a7287a 4070 49d1 9122 bf6169f67cd1)
Version | 1.0 |
Category | E-blocks 2 |
Switch component
A set of 8 push switches that can be connected to an E-blocks 2 upstream board via a port connector. Switches are wired in an active high configuration.
Please click here to download the component source project: FC_Comp_Source_EBlocks2_Switch_BL0145.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_Switch_BL0145.fcfx
ReadAll
ReadAll | |
Reads all of the switches at once, returning a byte containing one bit per switch. | |
- BYTE | Return |
ReadState
ReadState | |
Read the state of the switch at the given index. | |
- BYTE | Index |
The switch to read the status of. | |
- BOOL | Return |
WaitUntilHigh
WaitUntilHigh | |
Pause the program until the switch at the given index is turned on. | |
- BYTE | Index |
Index of the switch to wait for. | |
- VOID | Return |
WaitUntilLow
WaitUntilLow | |
- BYTE | Index |
- VOID | Return |
