Component: DAC Dual (MCP49x2) (Analog Output)
(Redirected from Component: ID b66f5769 5e9d 40e7 9159 c6a0552ff86e)
Version | 1.0 |
Category | Analog Output |
DAC Dual (MCP49x2) component
Component to drive a dual digital to analogue converter (DAC) IC from Microchip via an SPI interface. Compatible with MCP4902 (8-Bit), MCP4912 (10-Bit) and MCP4922 (12-Bit) devices.
Please click here to download the component source project: FC_Comp_Source_DAC_MCP49x2.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DAC_MCP49x2.fcfx
ControlPins
Disable
Disable | |
Disables the DAC output. | |
- BYTE | Channel |
0=DAC Channel 0 , 1=DAC Channel 1 | |
- VOID | Return |
Enable
Enable | |
Enables the DAC Output. | |
- BYTE | Channel |
- VOID | Return |
Initialise | |
Configures the SPI peripheral ready for communications and initialises the internal variables. DAC needs to be enabled before any output voltage can be generated. | |
- VOID | Return |
SetOutput
