Component: API (ECIO28P) (API Slave Devices)
Version 2.0
Category API Slave Devices
API (ECIO28P) component
Connects to an ECIO28P running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / ADC / I2C / SPI / PWM / UART See Flowcode Help Wiki for firmware.
Please click here to download the component source project: FC_Comp_Source_ECIO28P_API_Comp.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ECIO28P_API_Comp.fcfx
The App Developer (ECIO28P) component allows an ECIO28P board to be controlled from within the Flowcode simulation runtime.
To allow Flowcode to communicate and control the ECIO28P hardware the board must first be pre-programmed with dedicated firmware.
The firmware hex file and Flowcode source project can be downloaded from here.
ZIP Icon.png ECIO28P App Developer Firmware
The COM port to the ECIO hardware is selected via the SCADA_ECIO28P component COM port property.
When building the component into a App Developer project remember to expose the COM port property to allow the end user to select the correct port for the hardware.
  • fixed statistics showing IO / ADC inputs / PWM
  • scrolling log showing all commands and returns
Pin Mapping
App Developer Slave Digital Pin 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18
Device Port Pin A0 A1 A2 A3 A4 A5 B0 B1 B2 B3 B4 B5 B6 B7 C0 C1 C2 C6 C7
App Developer Slave Analogue Pin 0 1 2 3 4 5 6 7 8 9 10 11 12
Device Port Pin A0 A1 A2 A3 A5 B2 B3 B1 B4 B0
App Developer Slave Peripheral Pin I2C SDA I2C SCL SPI MOSI SPI MISO SPI SCK UART RX UART TX PWM 0 PWM 1
Device Port Pin B0 B1 C7 B0 B1 C7 C6 C2 C1
Direct Slave Access
Here is a simple demo to switch on and off digital pin 5 (the LED pin).
FC6 Icon.png ECIO28P App Developer Example
ADCSample10
Fc9-comp-macro.png ADCSample10
Reads the voltage present on an Alanog pin as an 10-bit value range 0-1023
Fc9-u8-icon.png - BYTE ADCChannel
Range: 0-12
ADCSample8
Fc9-comp-macro.png ADCSample8
Reads the voltage present on an Alanog pin as an 8-bit value range 0-255
Range: 0-12
ADCSampleArray10
Fc9-comp-macro.png ADCSampleArray10
Range: 0-5
Fc9-u8-icon.png - BYTE SampleCount
Range: 1- 32
Fc9-u16-icon.png - UINT SampleDelay
Fc9-u16-icon.png - UINT Samples
ADCSampleArray8
Fc9-comp-macro.png ADCSampleArray8
Reads the voltage present on an Analog pin as an 8-bit value range 0-255 Performs the selected number of samples with the selected time in microseconds in between samples and returns each sample in a single packet
Range: 0-5
Range: 1- 32
Fc9-u8-icon.png - BYTE Samples
8-bit samples returned from the function
ADCSampleAverage10
Fc9-comp-macro.png ADCSampleAverage10
Range: 0-5
Range: 1- 100
Fc9-u8-icon.png - BYTE SampleDelay
ADCSampleAverage8
Fc9-comp-macro.png ADCSampleAverage8
Range: 0-5
Range: 1- 100
ADCSetPrechargeTime
Fc9-comp-macro.png ADCSetPrechargeTime
Specifies the precharge time for the ADC input readings in microseconds. The longer the time the more immune to noise the reading will be.
Fc9-u8-icon.png - BYTE ChargeTime
Default 10
ADCSetReferenceVoltage
Fc9-comp-macro.png ADCSetReferenceVoltage
Specified the reference setting for ADC reads.
Fc9-u8-icon.png - BYTE RefType
0=AREF, 1=VCC, 3=Internal 1.1V
I2CInitialise
Fc9-comp-macro.png I2CInitialise
Fc9-u8-icon.png - BYTE Baud
0=100KHz, 1=400KHz, 2=1MHz
I2CReceive
Fc9-comp-macro.png I2CReceive
Fc9-bool-icon.png - BOOL Last
I2CRestart
Fc9-comp-macro.png I2CRestart
I2CSend
Fc9-comp-macro.png I2CSend
I2CStart
Fc9-comp-macro.png I2CStart
I2CStop
Fc9-comp-macro.png I2CStop
I2CTransInit
Fc9-comp-macro.png I2CTransInit
Fc9-u8-icon.png - BYTE DeviceAddress
7-bit Device Address
I2CTransReceive
Fc9-comp-macro.png I2CTransReceive
Data variable to receive into
Fc9-u16-icon.png - UINT Count
Number of bytes to receive
I2CTransSend
Fc9-comp-macro.png I2CTransSend
Data to send
IOGetInputPin
Fc9-comp-macro.png IOGetInputPin
Fc9-u8-icon.png - BYTE Pin
Range: 0-18
IOSetOutputPin
Fc9-comp-macro.png IOSetOutputPin
Range: 0-18
Fc9-bool-icon.png - BOOL State
Range: 0-1
Fc9-comp-macro.png Initialise
PWMDisable
Fc9-comp-macro.png PWMDisable
Disable a PWM output
Range: 0-1
PWMEnable
Fc9-comp-macro.png PWMEnable
Enable a PWM output
Range: 0-1
PWMSetDuty
Fc9-comp-macro.png PWMSetDuty
Range: 0-5
Fc9-u8-icon.png - BYTE Duty
PWMSetPrescaler
Fc9-comp-macro.png PWMSetPrescaler
Fc9-u8-icon.png - BYTE Period
Default 255
RegisterRead
Fc9-comp-macro.png RegisterRead
Read one of the registers on-board the device
Fc9-u16-icon.png - UINT RegisterAddress
The address of the register
RegisterWrite
Fc9-comp-macro.png RegisterWrite
Writes to one of the registers on-board the device
The data value to assign to the register
SPIInitialise
Fc9-comp-macro.png SPIInitialise
SPIPrescaler
Fc9-comp-macro.png SPIPrescaler
Range: 0-2
SPITransfer
Fc9-comp-macro.png SPITransfer
SPITransferTrans
Fc9-comp-macro.png SPITransferTrans
Outgoing data
Fc9-u8-icon.png - BYTE DataIn
Incoming data
UARTBaud
Fc9-comp-macro.png UARTBaud
Fc9-u8-icon.png - BYTE Rate
UARTCheckRX
Fc9-comp-macro.png UARTCheckRX
UARTInitialise
Fc9-comp-macro.png UARTInitialise
UARTReceive
UARTSend
Fc9-comp-macro.png UARTSend
Fc9-conn-icon.png Connection
Fc9-type-7-icon.png Auto Detect Port
Fc9-type-16-icon.png COM Port
Lists all the current available COM port hardware on your PC.
Fc9-type-7-icon.png Refresh Ports
Fc9-conn-icon.png API Peripherals
Fc9-type-21-icon.png Digital IO
Fc9-type-21-icon.png Analog Input
Fc9-type-21-icon.png Analog Output
Fc9-type-21-icon.png PWM Output
Fc9-type-21-icon.png I2C Bus
Fc9-type-21-icon.png SPI Bus
Fc9-type-21-icon.png UART
Fc9-type-21-icon.png SERVO
Fc9-conn-icon.png Console
Fc9-type-7-icon.png Console Log
Create an automatic console log of the commands sent to the Arduino
Fc9-type-16-icon.png Log Mode
Controls how the console data is formatted. Fixed statistics gives an easy to read overview of the IO, Analog and PWM functionality Command Log gives a more in depth analysis of the outgoing commands and incoming returns ASCII mode allows serial data to be shown in raw text form, other commands are shown as in the Command Log mode
