Component: Temperature Sensor (Grove 101020015) (101020015) (Environmental)
Category Environmental
Temperature Sensor (Grove 101020015) component
Temperature Sensor uses a thermistor to measure ambient temperature. The resistance of thermistor changes based on ambient temperature. This resistance value alters the output of a voltage divider which is measured by an analog input pin and converted to a temperature value. The operating range is -40 to 125°C , with an accuracy of 1.5°C .
Please click here to download the component source project: FC_Comp_Source_TemperatureSensor.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TemperatureSensor.fcfx
GetTempFloat
Fc9-comp-macro.png GetTempFloat
Reads the temperature of the temperature sensor and returns as a floating point value.
GetTempInt
Fc9-comp-macro.png GetTempInt
Reads the temperature of the temperature sensor and returns as an integer value.
Fc9-s16-icon.png - INT Return
Fc9-conn-icon.png Simulation
Fc9-type-1-icon.png Tang Color
Colour of the moving part of the slider.
Fc9-type-1-icon.png Marker Color
Colour of the marker line across the slider tang.
Fc9-type-6-icon.png Channel
Fc9-conn-icon.png Settings
Fc9-type-14-icon.png Aquisition cycles
