Author
Matrix Ltd
Version
1.0
Category
Segment
7Segment (Quad TM1637) component
Quad seven segment display using an two pin communications bus to reduce the number of control pins. Driven using a TM1637 quad 7-segment display driver.
Please click here to download the component source project: FC_Comp_Source_TM1637_7SEG_Quad_Driver.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TM1637_7SEG_Quad_Driver.fcfx
SetBrightness
SetBrightness
Controls the brightness of the 7-seg displays
- BYTE
Brightness
Range: 0-7 - 0=Darkest, 7=Brightest
- BOOL
On
0 = Display Off, 1 = Display On
ShowDigit
ShowDigit
Set the number to be displayed in the given digit of the display. The colon character can also be controlled when writing to digit 1.
- BYTE
Digit
Which of the four digits to change. (0...3)
- BYTE
Value
The number value to set the digit to (0...15), 16=Clear
- BYTE
Colon
Whether to show the colon character. Digit 1 only.
ShowDigits
ShowDigits
Set the number and decimal point to be displayed in the given digit of the display.
- BYTE
Value0
- BYTE
Value1
- BYTE
Value2
- BYTE
Value3
- BYTE
Colon
ShowSegments
ShowSegments
Allows for manual control over the display segments. The colon character can also be controlled when writing to digit 1.
- BYTE
Digit
- BYTE
Segments
The binary segment value to display
Display Type
Set this according to the specification of your hardware display. Common Anode: Pin true -> LED Off, Pin false -> LED On Common Cathode: Pin true -> LED On, Pin false -> LED Off
Show Seg Labels
Show segment name labels overlayed over the component.
DIO
Data Pin connection to TM1637 IC
CLK
Clock Pin connection to TM1637 IC
Colors
LED Color
Color of the LED segments when truned on. When off, they use a much darker shade of the same hue.
Body Color
Color of the plastic casing containing the LEDs.
Label Color
Color for the optional LED segment labels.
