Component: Keypad (EB014) (E-blocks 1)
(Redirected from Component: ID e871d984 b0e0 4185 8d94 b11d28040996)
Version | 1.0 |
Category | E-blocks 1 |
Keypad component
Preset keypad based around the 3 * 4 unit, as used by the Matrix EB014 E-block
Please click here to download the component source project: FC_Comp_Source_Keypad_EB014.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Keypad_EB014.fcfx
Basic Example
Keypad Example File demonstrating controlling a door lock.
LED is used to show the pin status controlling the door lock.
GetAscii
GetAscii | |
Gets the ASCII value for the current keypress. If no key is pressed then the macro returns the value 255. | |
- BYTE | Return |
GetIndex
GetIndex | |
Gets the index value for the current keypress. If no key pressed then the macro returns the value 255. | |
- BYTE | Return |
GetNumber
GetNumber | |
Gets the numeric value for the current keypress. If no key pressed then the macro returns the value 255. | |
- BYTE | Return |
GetString
GetString | |
Gets the ASCII value for the current keypress and returns in the form of a string. If no key pressed then the macro returns the value 255. | |
- STRING | Return |
WaitPressed
WaitPressed | |
Blocking call that waits for one of the keys on the keypad to be pressed. The index of the key that was pressed is passed back to the user. | |
- BYTE | Return |
WaitReleased
WaitReleased | |
Blocking call that waits for the keys on the keypad to be released. If no key is pressed then the function will return immediatley. | |
- VOID | Return |
