Component: API (Interface Board) (API Slave Devices)
Category API Slave Devices
API (Interface Board) component
Connects to an Interface Board running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / ADC / I2C / SPI / PWM / UART / DAC / Servo See Instructables for open source project files.
Please click here to download the component source project: FC_Comp_Source_Interface_Board_Comp.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Interface_Board_Comp.fcfx
A board designed to allow PC access to embedded style electronic signals at 3V3 or 5V.
Includes: ADC / DAC / I2C / IO / Servo / SPI / UART
USB Firmware allows control via a USB connection. Works with a Windows PC but should also work with other USB master based devices.
WIFI Firmware allows control via a WIFI network connection. Works with any networked device including devices via the internet. WIFI connection requires the use of the UART peripheral and so this is not available for Slave functionality when using the WIFI firmware.
Board supplied with firmware as requested. Firmware can be changed using a PICkit 3 or PICkit 4 device or similar Microchip programmer.
To setup the WIFI to work with your own network you first need to power up the board using a USB connection or by applying a 5V power supply between the 5V and GND pins. Next connect to the WIFI network hosted by the board with the network name InterfaceBoard using password all in lowercase as the Password. Visit the website at page 192.168.4.1 and then enter your WIFI network details into the form provided. On clicking ok the board will store the details in none volatile memory and attempt to connect to your network and establish a local IP address. If all goes ok here then the Interface Board network should dissappear.
Refer to your router configuration page to see the IP address of the device.
If the WIFI network is not available then the board will revert back to it's setup mode allowing the network to be changed. Once network connection is available again the board will automatically reconnect.
The latest updates can be found on github
Direct Slave Access
Here is a simple demo to switch on and off digital pin 5.
FC6 Icon.png Simple Interface Board Demo
ADCSample10
Fc9-comp-macro.png ADCSample10
Reads the voltage present on an Alanog pin as an 10-bit value range 0-1023
Fc9-u8-icon.png - BYTE ADCChannel
Range: 0-5
ADCSample8
Fc9-comp-macro.png ADCSample8
Reads the voltage present on an Alanog pin as an 8-bit value range 0-255
Range: 0-5
I2CInitialise
Fc9-comp-macro.png I2CInitialise
Fc9-u8-icon.png - BYTE Baud
0=100KHz, 1=400KHz, 2=1MHz
I2CReceive
Fc9-comp-macro.png I2CReceive
Fc9-bool-icon.png - BOOL Last
I2CRestart
Fc9-comp-macro.png I2CRestart
I2CSend
Fc9-comp-macro.png I2CSend
I2CStart
Fc9-comp-macro.png I2CStart
I2CStop
Fc9-comp-macro.png I2CStop
I2CTransInit
Fc9-comp-macro.png I2CTransInit
Fc9-u8-icon.png - BYTE DeviceAddress
7-bit Device Address
I2CTransReceive
Fc9-comp-macro.png I2CTransReceive
Data variable to receive into
Fc9-u16-icon.png - UINT Count
Number of bytes to receive
I2CTransSend
Fc9-comp-macro.png I2CTransSend
Data to send
IOGetInputPin
Fc9-comp-macro.png IOGetInputPin
Fc9-u8-icon.png - BYTE Pin
Range: 0-17
IOSetOutputPin
Fc9-comp-macro.png IOSetOutputPin
Range: 0-17
Fc9-bool-icon.png - BOOL State
Range: 0-1
Fc9-comp-macro.png Initialise
PWMDisable
Fc9-comp-macro.png PWMDisable
Disable a PWM output
Range: 0-1
PWMEnable
Fc9-comp-macro.png PWMEnable
Enable a PWM output
Range: 0-1
PWMSetDuty8
Fc9-comp-macro.png PWMSetDuty8
Range: 0-1
Fc9-u8-icon.png - BYTE Duty
Range: 0-255
PWMSetPrescaler
Fc9-comp-macro.png PWMSetPrescaler
SPIInitialise
Fc9-comp-macro.png SPIInitialise
SPIPrescaler
Fc9-comp-macro.png SPIPrescaler
Range: 0-2
SPITransfer
Fc9-comp-macro.png SPITransfer
SPITransferTrans
Fc9-comp-macro.png SPITransferTrans
Outgoing data
Fc9-u8-icon.png - BYTE DataIn
Incoming data
ServoDisable
Fc9-comp-macro.png ServoDisable
Disable a Servo output
Range: 0-5
ServoEnable
Fc9-comp-macro.png ServoEnable
Enable a Servo output
Range: 0-5
ServoSetPosition8
Fc9-comp-macro.png ServoSetPosition8
Sets the position as an 8-bit value
Range: 0-1
Fc9-u8-icon.png - BYTE Position
Range: 0-255
UARTBaud
Fc9-comp-macro.png UARTBaud
Fc9-u8-icon.png - BYTE Rate
UARTCheckRX
Fc9-comp-macro.png UARTCheckRX
UARTInitialise
Fc9-comp-macro.png UARTInitialise
UARTReceive
UARTSend
Fc9-comp-macro.png UARTSend
WIFIGetIP
Fc9-comp-macro.png WIFIGetIP
Gets the IP address of the board. Allows you to setup and get the assigned address via USB before using over WIFI, Use the WIFIIsConnected first to check the WIFI is active.
WIFIIsConnected
Fc9-comp-macro.png WIFIIsConnected
Checks to see if the WIFI is active and connected
WIFISetSSID
Fc9-comp-macro.png WIFISetSSID
Assign the SSID and password for the network you wish to connect the board to. Stores the parameters into ROM for later USB free setup.
Fc9-string-icon.png - STRING SSID
Name of the network you wish to connect to
Fc9-string-icon.png - STRING Password
Fc9-type-16-icon.png Connection Type
Fc9-conn-icon.png Connection Properties
Fc9-type-7-icon.png Auto Detect Port
Allows the component to auto detect the interface board COM port. Requires the latest Flowcode serial comms DLL to function correctly.
Fc9-type-16-icon.png Scan Results
Lists the IP addresses found during the last scan, Overwrites the selected WIFI IP property when changed.
Fc9-type-21-icon.png Scan Start
Address to set the scan start point. For example 10 might generate 192.168.1.10 depending on your IP setting. Scan then proceeds from there so for example 11, 12, 13, ..., 254, 255. Default 0
Fc9-type-16-icon.png End Scan
Decides how the scan is terminated
Fc9-conn-icon.png API Peripherals
Fc9-type-21-icon.png Digital IO
Fc9-type-21-icon.png Analog Input
Fc9-type-21-icon.png Analog Output
Fc9-type-21-icon.png PWM Output
Fc9-type-21-icon.png I2C Bus
Fc9-type-21-icon.png SPI Bus
Fc9-type-21-icon.png UART
Fc9-type-21-icon.png SERVO
Fc9-conn-icon.png Logging
Fc9-type-7-icon.png Console Log
Create an automatic console log of the commands sent to the device
Fc9-type-16-icon.png Log Mode
Controls how the console data is formatted. Fixed statistics gives an easy to read overview of the IO, Analog and PWM functionality Command Log gives a more in depth analysis of the outgoing commands and incoming returns ASCII mode allows serial data to be shown in raw text form, other commands are shown as in the Command Log mode
Fc9-type-7-icon.png Show Raw
Shows the raw data stream via a console window
