Component: Webserver (EB023 v2) (E-blocks 1)
(Redirected from Component: ID ee1635e0 3008 4836 89e1 005435f4a33d)
Version | 2.0 |
Category | E-blocks 1 |
- 1 Webserver component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 CheckSocketActivity
- 5.2 CreateServerSocket
- 5.3 GetInValue
- 5.4 IncRxPtr
- 5.5 Initialise
- 5.6 MIAC_Module_GetData
- 5.7 MIAC_Module_Message
- 5.8 MIAC_Module_PushData
- 5.9 MIAC_Module_SetData
- 5.10 Send_Embedded_HTML_Page1
- 5.11 Send_Embedded_HTML_Page2
- 5.12 Send_Embedded_HTML_Page3
- 5.13 Send_Embedded_HTML_Page4
- 5.14 SetOutValue
- 5.15 WM_CH_CR
- 5.16 WM_CH_IR
- 5.17 WM_CH_MR
- 5.18 WM_CH_PORT
- 5.19 WM_CH_RX_RSR
- 5.20 WM_CH_SR
- 5.21 WM_CH_TX_WR
- 5.22 WM_RXMEM
- 5.23 WM_TXMEM
- 6 Property reference
Webserver component
Webserver component designed to work with the WIZ810MJ module from Wiznet, as used in the version 2 EB023 E-block and MIAC System Industrial Addon. Provides a very simple interface to allow webpages to be hosted from hardware or simulation.
Please click here to download the component source project: FC_Comp_Source_WebServer_EB023-00-2_EB.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_WebServer_EB023-00-2_EB.fcfx
CheckSocketActivity
CheckSocketActivity | |
Checks for activity on the server socket and serves out the webpages to any requesting parties. | |
- BYTE | Return |
CreateServerSocket
CreateServerSocket | |
Creates a listening socket on the selected channel and port ready to accept incoming web page requests. | |
- BYTE | Channel |
- UINT | Port |
- BYTE | Return |
GetInValue
GetInValue | |
Returns the string value of a Request parameter | |
- BYTE | index |
- STRING | Return |
IncRxPtr
IncRxPtr | |
- BYTE | Channel |
- VOID | Return |
MIAC_Module_GetData
MIAC_Module_GetData | |
- BYTE | Index |
- BYTE | Return |
MIAC_Module_Message
MIAC_Module_Message | |
- UINT | CAN_ID |
- UINT | CMD_ID |
- BYTE | Return |
MIAC_Module_PushData | |
- BYTE | Data |
- VOID | Return |
MIAC_Module_SetData
MIAC_Module_SetData | |
- BYTE | Count |
- BYTE | D0 |
- BYTE | D1 |
- BYTE | D2 |
- BYTE | D3 |
- BYTE | D4 |
- BYTE | D5 |
- VOID | Return |
Send_Embedded_HTML_Page1 | |
- VOID | Return |
Send_Embedded_HTML_Page2 | |
- VOID | Return |
Send_Embedded_HTML_Page3 | |
- VOID | Return |
Send_Embedded_HTML_Page4 | |
- VOID | Return |
SetOutValue
SetOutValue | |
Set the value of an outbound substitution string | |
- BYTE | index |
- STRING | value |
- VOID | Return |
WM_CH_CR
WM_CH_CR | |
- BYTE | ch |
- UINT | Return |
WM_CH_IR
WM_CH_IR | |
- BYTE | ch |
- UINT | Return |
WM_CH_MR
WM_CH_MR | |
- BYTE | ch |
- UINT | Return |
WM_CH_PORT
WM_CH_PORT | |
- BYTE | ch |
- UINT | Return |
WM_CH_RX_RSR
WM_CH_RX_RSR | |
- BYTE | ch |
- UINT | Return |
WM_CH_SR
WM_CH_SR | |
- BYTE | ch |
- UINT | Return |
WM_CH_TX_WR
WM_CH_TX_WR | |
- BYTE | ch |
- UINT | Return |
WM_RXMEM
WM_RXMEM | |
- BYTE | ch |
- UINT | Return |
WM_TXMEM
WM_TXMEM | |
- BYTE | ch |
- UINT | Return |
