Component: WLAN (ESP32) (Comms: Networking)
Author Matrix Ltd.
Version 2.4
Category Comms: Networking
WLAN (ESP32) component
Wireless LAN component designed to work with ESP32 modules
Please click here to download the component source project: FC_Comp_Source_WLAN_ESP32.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_WLAN_ESP32.fcfx
Weather Predictor
Here is an example of a next-day weather predictor that also shows the current-day weather for a ESP32 embedded device
It uses the BBC weather component via Netwoekcomms and WLAN ESP32 components to connect to the BBC server and retrieve the weather forecast for the specified area code.
FC6 Icon.png ESP32 weather predictor
User Configurable Network Details
When creating a product using an ESP32 device it is important that it can connect to the network of the person buying the product.
This is complicated as the ESP32 requires that the network SSID and password be defined by the user and this requires a means of getting the data into the ESP32 device.
Luckily as the ESP32 features the ability to host it's own network we can use this to create a simple web interface where the user can enter their network details.
FC6 Icon.png ESP32 Config WIFI
More info on this available here Flowcode Forums - User Configurable Network Details
AcceptClose
Fc9-comp-macro.png AcceptClose
Close the socket associated with the Accepted incoming connection
AcceptOpen
Fc9-comp-macro.png AcceptOpen
Returns 1 if there is an incoming connection on the listening port
ConnectToSSID
Fc9-comp-macro.png ConnectToSSID
Attempts to connect to the given SSID and Key values. Returns 1 if the SSID has been connected.
Fc9-string-icon.png - STRING SSID
Fc9-string-icon.png - STRING Key
Fc9-u8-icon.png - BYTE Timeout
Number of seconds to wait for the connection, default 20
CreateAccessPoint
Fc9-comp-macro.png CreateAccessPoint
Sets up the wireless LAN module into AP mode to host a wireless network. Other WIFI enabled devices can then connect to the module. Returns 1 for success.
Name of the wireless network to create
Fc9-string-icon.png - STRING Password
Password used to gain access to the network
802.11 Channel Range 1-14
Fc9-u8-icon.png - BYTE Encryption
0=Open, 1=WEP, 2=WPA_PSK, 3=WPA2_PSK, 4=WPA_WPA2_PSK
Disconnect
Fc9-comp-macro.png Disconnect
Attempts to disconnect from the SSID.
Fc9-comp-macro.png Initialise
Initialise the WiFi system Returns 1 if successful Returns 0 if not
ReadEncryptionModeFromScan
Fc9-comp-macro.png ReadEncryptionModeFromScan
Collects one of the encryption modes from the last SSID Scan. The ScanForSSID macro must be called first. 0=Open, 1=WEP, 2=WPA_PSK, 3=WPA2_PSK, 4=WPA_WPA2_PSK
Fc9-u8-icon.png - BYTE Index
SSID Index
ReadIP
Fc9-comp-macro.png ReadIP
Collects a single byte from the local IP address. For example 192.168.0.1 Index = 3 : Return = 192 / Index = 0 : Return = 1
Range: 0 to 3 Where 3 = the first number and 0 = the last number
ReadIPString
Fc9-comp-macro.png ReadIPString
Collects the local IP address and returns it as an ASCII string. e.g. "192.168.0.1"
ReadSSIDFromScan
Fc9-comp-macro.png ReadSSIDFromScan
Collects one of the SSID name strings from the last SSID Scan. The ScanForSSID macro must be called first.
SSID Index
ReadSignalStrengthFromScan
Fc9-comp-macro.png ReadSignalStrengthFromScan
Collects the signal strength from the last SSID Scan. The ScanForSSID macro must be called first. Value returned is in negative dB, smaller value = better signal
SSID Index
Fc9-s16-icon.png - INT Return
ScanForSSID
Fc9-comp-macro.png ScanForSSID
Checks for wireless networks in the local area which are broadcasting their SSID. Must not be connected to a network to allow this to function. Returns the number of wireless networks found, max 8.
SocketClose
Fc9-comp-macro.png SocketClose
SocketConnect
Fc9-comp-macro.png SocketConnect
Fc9-string-icon.png - STRING Address
Fc9-u16-icon.png - UINT Port
SocketListen
Fc9-comp-macro.png SocketListen
Listen on, or bind, local port to already opened socket. Returns 1 if OK, 0 if fail
SocketOpen
Fc9-comp-macro.png SocketOpen
Returns 1 if socket sucessfully opened
SocketRead
Fc9-comp-macro.png SocketRead
Fc9-string-icon.png - STRING Buffer
Fc9-u16-icon.png - UINT Size
SocketWrite
Fc9-comp-macro.png SocketWrite
Uninitialise
Fc9-comp-macro.png Uninitialise
Shuts down the WiFi system for low power operation. Returns 1 if successful Returns 0 if not
Fc9-type-7-icon.png Verbose Debug
Provides verbose debugging output via hardware UART channel 1 which is often connected to a UART to USB bridge.
Fc9-type-21-icon.png SSID Scan Size
Maximum number of SSIDs that can be detailed from a single SSID network scan. Default 8
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png Network Interface
List of network interfaces connected to the PC. Sets which interface we are communicating via.
Generate Console Data
