Component: DAC (MCP48x1) (MCP48x1) (Analog Output)
Category Analog Output
DAC (MCP48x1) component
Component to drive a digital to analogue converter (DAC) IC from Microchip via an SPI interface. Compatible with MCP4801 (8-Bit), MCP4811 (10-Bit) and MCP4821 (12-Bit) devices.
Please click here to download the component source project: FC_Comp_Source_DAC_MCP48x1.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DAC_MCP48x1.fcfx
ControlPins
Fc9-comp-macro.png ControlPins
Allows Shutdown (SHDN) and Latch (LDAC) pins to be controlled directly if enabled.
Fc9-bool-icon.png - BOOL Shutdown
0 = Shutdown Device, 1 = Device Active
Fc9-bool-icon.png - BOOL Latch
0 = Data output driven from DAC register, 1 = Data output locked
Disable
Fc9-comp-macro.png Disable
Disables the DAC output.
Enable
Fc9-comp-macro.png Enable
Enables the DAC Output.
Fc9-comp-macro.png Initialise
Configures the SPI peripheral ready for communications and initialises the internal variables. DAC needs to be enabled before any output voltage can be generated.
SetOutput
Fc9-comp-macro.png SetOutput
Sets the output voltage of the DAC 8-Bit: Range 0-255 10-Bit: Range 0-1023 12-Bit: Range 0-4095
Fc9-u16-icon.png - UINT DAC_Value
The value to output to the DAC
Fc9-type-16-icon.png DAC IC
Selects which DAC IC is connected and therefore the bit depth available.
Fc9-type-16-icon.png Gain Option
Fc9-type-15-icon.png Vref Voltage
Fc9-type-21-icon.png Steps
Number of discrete output states available from the DAC.
Fc9-type-14-icon.png Control Bits
Fc9-type-10-icon.png Resolution
Fc9-type-15-icon.png Voltage Resolution
Fc9-conn-icon.png SPI Connections
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-5-icon.png MOSI
Fc9-type-16-icon.png MOSI Remap Pin
Fc9-type-5-icon.png MISO
Fc9-type-16-icon.png MISO Remap Pin
Fc9-type-5-icon.png CLK
Fc9-type-16-icon.png CLK Remap Pin
Fc9-type-5-icon.png CS / SS
Fc9-type-7-icon.png Use SHDN Pin
Allows the SHDN pin to be driven from an output pin on the microcontroller. If not used then tie the SHDN pin to VCC to allow the DAC to function.
Fc9-type-7-icon.png Use LDAC Pin
Allows the LDAC pin to be driven from an output pin on the microcontroller. If not used then tie the LDAC pin to GND to allow the DAC to function.
Fc9-conn-icon.png Simulation
