Component: Object Helper ( Data)
Jump to navigationJump to searchAuthor | MatrixTSL |
Version | 0.1 |
Category | Data |
Object Helper component
Component to help when dealing with Javascript objects.
Please click here to download the component source project: FC_Comp_Source_WEBEXP_Object.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_WEBEXP_Object.fcsx
Weather Example
Example program showcasing a number of components used together to collect data from a URL using fetch, before processing the data using the object helper and array helper components.
GetKeys
GetKeys | |
Returns a list of the JavaScript object's keys | |
- HANDLE | Object |
The JavaSctipt object | |
- HANDLE | Return |
GetValue
GetValue | |
Gets the value for a key in a JavaScript object | |
- HANDLE | Object |
The JavaScript object | |
- STRING | sKey |
The key name | |
- HANDLE | Return |
JSONToObject
JSONToObject | |
Converts a JSON string to a JavaScript object | |
- STRING | Text |
The JSON string to convert to a JavaScript object | |
- HANDLE | Return |
NumberToObject
NumberToObject | |
Converts a number to a JavaScript object | |
- LONG | Var |
The number to convert to a JavaSctipt object | |
- HANDLE | Return |
ObjectToFloat
ObjectToFloat | |
Converts an object to a floating point value | |
- HANDLE | Object |
- FLOAT | Return |
ObjectToInteger
ObjectToInteger | |
Converts an object to an integer | |
- HANDLE | Object |
- LONG | Return |
ObjectToJSON
ObjectToJSON | |
Converts an object to a JSON string | |
- HANDLE | Object |
- STRING | Return |
ObjectToNumber
ObjectToNumber | |
Converts an object to a number | |
- HANDLE | Object |
- FLOAT | Return |
ObjectToString
ObjectToString | |
Converts an object to a string | |
- HANDLE | Object |
- STRING | Return |
SetValue
StringToObject
StringToObject | |
Converts a string to a JavaScript object | |
- STRING | Var |
The string to convert to a JavaScript object | |
- HANDLE | Return |
Properties |
