Component: LCD control (Simulation)
Revision as of 12:51, 21 July 2016 by BenR (talk | contribs) (XML import)
Version 1.0 (Release)
Category Simulation
Image LCD control component
An LCD control pane supporting up to 64 x 64 units Suitable for simulation only
This component does not contain any downloadable macros
Simulation macro reference
Clear
This macro has no parameters
AddChar
Adds a text character to the LCD at a given position
INT X
X location of the text to add
INT Y
Y location of the text to add
BYTE Text
The text character to add
GetScrollX
Gets the scroll position in X set by SetScrollX()
UINT
SetScrollX
Sets the scroll offset in X of the LCD
UINT Pos
AddText
Adds a text string to the LCD at a given position
INT X
INT Y
STRING Text
The text to add
SetSize
Sets the size of the LCD grid
BYTE X
The number of X cells
BYTE Y
The number of Y cells
Horizontal size
This property is of type Signed integer and can be referenced with the variable name CellX.
Vertical size
This property is of type Signed integer and can be referenced with the variable name CellY.
Horizontal buffer
This property is of type Signed integer and can be referenced with the variable name WidthX.
Text color
This property is of type Color picker and can be referenced with the variable name TextCol.
Text font
This property is of type Font picker and can be referenced with the variable name TextFont.
Background color
This property is of type Color picker and can be referenced with the variable name BackCol.
Line color
This property is of type Color picker with transparency and can be referenced with the variable name LineCol.
