Component: ADC (CAL)
Author | Matrix Ltd |
Version | 1.3 (Release) |
Category | CAL |
ADC component
A low level implementation giving direct access to the CAL
Disable
Disables the current ADC channel
Call this once sampling is complete
Enable
Enables sampling of the ADC channel
This is called every time a new ADC channel needs configuring to ADC mode
[u]Only one ADC channel may be enabled at any time[/u]
When sampling is complete, call Disable() to restore the pin
- BYTE Channel
- A value >= 0 specifying the ADC channel
- BYTE Conv_Speed
- Chip-specific rate of change read from the FCD <ADC.ConfSpeed>
- BYTE Vref
- 0 to disable Vref mode, else 1
- BYTE T_Charge
- Aquisition time to wait in micro seconds
Sample
Blocking call to read a sample on the currently enabled channel
- BYTE Sample_Mode
- True to enable full-width sample (10 or 12 bits), else false for 8 bit
- UINT : The sample value, as an 8, 10 or 12 bit value 0->N
Simulation macro reference
GetValue
Gets the Name property value
- STRING Name
- The name of the property
SetValue
Sets the Value for the named property
- STRING Name
- Name of property to update
- STRING Value
- The new value for the property
GetList
- STRING Name
This property is of type Signed integer and can be referenced with the variable name CHANNEL.
ADC Channel number
Vref Option
This property is of type Fixed list of ints and can be referenced with the variable name VREFOP.
selects the reference voltage option
Vref+ (x10mV)
This property is of type Signed integer and can be referenced with the variable name VREFVOL.
sets the value of the reference voltage (used for conversion calculations)
Acq Time
This property is of type Signed integer and can be referenced with the variable name ACTIME.
ADC acquisition time
Conv Speed
This property is of type Fixed list of ints and can be referenced with the variable name CONVSP.
Conversion speed option
Type
This property is of type Signed integer and can be referenced with the variable name TYPE.
Bits
This property is of type Signed integer and can be referenced with the variable name BITS.
This property is of type True or false and can be referenced with the variable name ScopeTraces.
