Component: Touch Screen (XPT2046) (Displays: Graphical)
Revision as of 15:46, 16 February 2017 by BenR (talk | contribs) (XML import BR)
Version 1.3 (Release)
Category Displays: Graphical
Image Touch Screen (XPT2046) component
Low level routines for controlling or interacting with the XPT2046 touch screen controller IC found on a lot of common low cost resistive touch screen products.
Example using the XPT2046 touchscreen driver IC with a 4.3" TFT Display using the SSD1963 Graphical LCD Controller. FC6 Icon.png GLCD 4.3 Touch Example using the XPT2046 touchscreen driver IC with a 7" TFT Display using the SSD1963 Graphical LCD Controller. FC6 Icon.png GLCD 7 Touch
SampleSensor
Reads the touch controller and returns true if there is currently a touch in progress.
The touch coordinates can be read using the ReadCoord macro.
Return 0 = No Touch, 1 = Touch in progress
This macro has no parameters
BYTE
ReadCoord
Reads a coordinate returned from the Sample Sensor macro.
Coordinate is scaled to the X/Y Pixel bounds specified.
BYTE Coordinate
0 = X, 1 = Y, 2 = Pressure
UINT
Activates the SPI peripheral and claims control over the I/O pins.
Simulation macro reference
GetConsoleHandle
HANDLE
SPI Channel
This property is of type Fixed list of ints and can be referenced with the variable name CHANNEL.
SPI peripher onboard the target microcontroller to use.
Prescale
This property is of type Fixed list of ints and can be referenced with the variable name PR_SCALE.
Rate by which the master oscillator is reduced before clocking the SPI peripheral.
CS
This property is of type Single digital pin and can be referenced with the variable name CS_Pin.
DAC enable pin - only used with the EB013 SPI E-block
MOSI (SDO)
This property is of type Single digital pin and can be referenced with the variable name MOSI.
Data Out Pin - Micro Out Serial In
MISO (SDI)
This property is of type Single digital pin and can be referenced with the variable name MISO.
Data In Pin - Micro In Serial Out
CLK
This property is of type Single digital pin and can be referenced with the variable name CLK.
Clock Pin
Analogue Mode
This property is of type Fixed list of ints and can be referenced with the variable name AnMode.
X Pixel
This property is of type Unsigned integer and can be referenced with the variable name Xpix.
Y Pixel
This property is of type Unsigned integer and can be referenced with the variable name Ypix.
Flip X
This property is of type True or false and can be referenced with the variable name FlipX.
Flip Y
This property is of type True or false and can be referenced with the variable name FlipY.
Label used to identify the component on the panel.
This property is of type True or false and can be referenced with the variable name ScopeTraces.
This property is of type True or false and can be referenced with the variable name ConsoleData.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name Injector.
Injector component to allow the data in simulation to be passed to something meaningful.
