Component: LED Matrix (HT16K33) (Outputs: LEDs)
Revision as of 14:09, 8 June 2018 by BenR (talk | contribs)
Version 1.2 (Release)
Category Outputs: LEDs
Image LED Matrix (HT16K33) component
LED Matrix component designed to work using a HT16K33 LED driver IC. Can drive up to 16 x 8 (128) LEDs. Includes support for 8x16 Backpack, 16x8 Featherwing, 8x8 Backpack and Custom.
Example to display a bitmap image on the LED matrix using the Bitmap Drawer component.
File:HT16K33 Bitmap.zip
DisplayString
Prints an ASCII string onto the LED Matrix a column at a time.
<- STRING Data
Data string to display on the LEDs
This parameter may be returned back to the caller
UINT Animation_Delay
Delay in milliseconds between writing to the next column
BYTE Leadout
Allows the text to scroll completely off the display before returning 0=No, 1=Yes
BYTE Add_Spaces
Add spaces between each ASCII character 0=No, 1=Yes
BYTE Orientation
0=Normal, 1=Rotated 90 Degrees
SetBrightness
Configures the brightness of the LEDs by varying the On portion of the duty.
BYTE Brightness
Range: 0-15 - 0 = Min Brightness, 15 = Full Brightness
ShiftColumns
Shifts the columns one place left or right.
Used for things like displaying scrolling text.
BYTE Direction
0 = Shift Left, 1 = Shift Right
ClearLEDs
Sets all of the LEDs in the matrix to the off state.
This macro has no parameters
WriteLED
Allows a single LED to be controlled using the basic column / row coordinate system.
Each column is comprised of 8 rows.
BYTE Column
Range: 0-15
BYTE Row
Range: 0-7
BYTE Data
0 = LED Off, 1 = LED On
WriteLEDXY
Allows a single LED to be controlled using a more standard X, Y coordinate system.
0,0 refers to the bottom left hand LED.
Only works with the fixed display modules, custom module not supported.
BYTE X
X coordinate. Range: 0-15
BYTE Y
Y coordinate. Range: 0-15
BYTE State
State 0=Off, 1=On
WriteCommand
Writes a command.
BYTE Command
WriteColumn
Allows a single column of 8 LEDs to be controlled in a single action.
BYTE Column
Range: 0-15
BYTE Data
Data to display on the column of LEDs
WriteRegister
Writes a value to a register.
BYTE Address
BYTE Value
Configures the I2C peripheral and sets up the HT16K33 IC ready to drive the LEDs.
Simulation macro reference
Display Module
This property is of type Fixed list of ints and can be referenced with the variable name Module.
LED Count
This property is of type Signed integer and can be referenced with the variable name led_cnt.
Total number of LEDs in the component
Slave Address
This property is of type Fixed list of ints and can be referenced with the variable name SlaveAddress.
This property is of type Fixed list of ints and can be referenced with the variable name cal_i2c1::CHANNEL.
Channel selection
Baud Select
This property is of type Fixed list of ints and can be referenced with the variable name cal_i2c1::BAUD_LIST.
This property is of type Signed integer and can be referenced with the variable name cal_i2c1::BAUD.
Baud rate to be used
Stop Delay
This property is of type True or false and can be referenced with the variable name cal_i2c1::StopDel.
On older microcontroller devices there is a potential for the I2C hardware channel to lock up if there is not
a 10ms delay between an I2C stop event and the next I2C start event.
Most modern microcontrollers will not have a problem so this property can be disabled to speed up the
I2C communications.
SDA
This property is of type Single digital pin and can be referenced with the variable name cal_i2c1::SDA.
SCL
This property is of type Single digital pin and can be referenced with the variable name cal_i2c1::SCL.
On Color
This property is of type Color picker and can be referenced with the variable name on_col.
Simulated colour of the LEDs when switched On
Off Color
This property is of type Color picker and can be referenced with the variable name off_col.
Simulated colour of the LEDs when switched Off
Simulation Type
This property is of type Fixed list of ints and can be referenced with the variable name SimType.
Sets the simulation type.
Component GUI allows the object on the panel to reflect what the reakl life LED matrix should do.
I2C Injector allows the I2C communications to be simulated via injectors.
Column Spacing
This property is of type Floating point and can be referenced with the variable name col_spacing.
Simulation column spacing
Width
This property is of type Floating point and can be referenced with the variable name width.
Simulation LED width
Row Spacing
This property is of type Floating point and can be referenced with the variable name row_spacing.
Simulation row spacing
Height
This property is of type Floating point and can be referenced with the variable name height.
Simulated LED height
Depth
This property is of type Floating point and can be referenced with the variable name depth.
Simulated LED Depth (3D environments only)
LED Shape
This property is of type Fixed list of ints and can be referenced with the variable name Shape.
Simulated LED basic shape
This property is of type True or false and can be referenced with the variable name cal_i2c1::ScopeTraces.
This property is of type True or false and can be referenced with the variable name cal_i2c1::ConsoleData.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name cal_i2c1::Injector.
