Component: Embed File (Storage)
Author | Matrix TSL |
Version | 1.0 (Release) |
Category | Storage |
Embed File component
A component to simplify the process of embedding files into ROM. Stores the file inside a ROM look up table.
Basic example program which embeds a text file into the microcontrollers ROM memory and then prints the file out to a LCD display. EmbedFileExample Text file to go with the example, must be placed into the same directory as the Flowcode file.
Here is an archive which packages the example and text file together for you.
The file is selected using the File component property.
Clicking the small arrow to the right of the property and selecting Browse allows you to select a file using a Windows file explorer.
GetFileByte
Reads a single byte from the file at the specified address.
- UINT Address
- Address range 0 to NumBytesInFile - 1
GetFileLength
Returns the file size in bytes.
Simulation macro reference
File
This property is of type Filename and can be referenced with the variable name file.
File you wish to embed into the program
File Length
This property is of type Unsigned integer and can be referenced with the variable name file_Len.
File size in bytes.
Max recommended file size = 65535 bytes
8-bit PICs may struggle with files larger than 256 bytes.
ROM Size
This property is of type Unsigned integer and can be referenced with the variable name RomSize.
Number of bytes available in the target device ROM memory
