Component: Grove Water Sensor (101020018) (Grove)
Author | Matrix Ltd |
Version | 1.0 (Release) |
Category | Grove |
Grove Water Sensor (101020018) component
The water sensor uses a 1M ohm pull-up resistor. The resistor will pull the sensor trace value high until a drop of water shorts the sensor trace to the ground trace. You can use it with an analog input pin to detect the amount of water in contact between the grounded and sensor traces. It indicates whether the sensor is dry, damp, or completely submerged in water by measuring conductivity.
There are two different macros in order to get the reading as a floating point or as a whole integer. Also, make sure that the water sensor is connected to the right channel in flowcode.
GetIntValue
Returns the analog reading as an integer value.
GetFloatValue
Reads the analog value as a floating point value between 0 and 100
Simulation macro reference
Tang Color
This property is of type Color picker and can be referenced with the variable name tang_col.
Colour of the moving part of the slider.
Marker Color
This property is of type Color picker and can be referenced with the variable name mark_col.
Colour of the marker line across the slider tang.
This property is of type True or false and can be referenced with the variable name ScopeTraces.
This property is of type Single analog pin and can be referenced with the variable name channel.
VRef voltage
This property is of type Signed integer and can be referenced with the variable name vrefvol.
Used by the GetVoltage or GetString component macros to take an ADC reading and convert it into a Voltage.
+VRef voltage x 10mV
Default 500 = 5.0V
VRef option
This property is of type Fixed list of ints and can be referenced with the variable name vrefop.
Defines what is used as the ADC maximum reference. ADC Range = GND to VRef Voltage.
VDD - Defines the microcontrollers power supply pin as the max reference,
VREF+ Pin - Dedicated pin on the microcontroller to allow for a variable reference voltage.
Conversion speed
This property is of type Fixed list of ints and can be referenced with the variable name convspd.
Clock setting to select how fast the ADC peripheral will perform an ADC conversion.
The FRC setting is based on a RC time base and so will vary with temperature and pressure.
Other settings are generally based on divisions of the master clock.
Aquisition cycles
This property is of type Signed integer and can be referenced with the variable name actime.
Bit Depth
This property is of type Signed integer and can be referenced with the variable name bits.
Maximum number of digital bits the ADC can sample.
8 bit = ADC range 0 - 255
10 bit = ADC range 0 - 1023
12 bit = ADC range 0 - 4095
