Component: Event Log (SCADA Tools)
Author | Matrix TSL |
Version | 1.0 (Release) |
Category | SCADA Tools |
Event Log component
A simulation component designed to create a simple log record of events in your SCADA system. Logs to a file and / or to a console tab including optional automated time stamp.
This component does not contain any downloadable macros
Simulation macro reference
LogEvent
Allows an event string to be logged
- <- STRING LogString
Log To Console
This property is of type True or false and can be referenced with the variable name LogToConsole.
Log To File
This property is of type True or false and can be referenced with the variable name LogToFile.
Include Timestamp
This property is of type True or false and can be referenced with the variable name IncludeTS.
Controls if a timestamp is appended to the start of the log string.
Yes: Add timestamp to log string
No: Leave log string as is
Console Name
This property is of type Line of text and can be referenced with the variable name ConsoleName.
Clear On Init
This property is of type True or false and can be referenced with the variable name ConsoleClear.
Selects if the contents of the console are maintained or wiped on runtime start.
Yes: Console is automatically cleared
No: Console is maintained and appended
Log File
This property is of type Filename and can be referenced with the variable name LogFile.
File to store the log data.
Default: $(srcdir)log.txt
$(srcdir) specifies the directory containing your Flowcode project file.
log.txt specifies a file named log.txt
If the file does not exist then it will be automatically created for you.
Clear On Init
This property is of type True or false and can be referenced with the variable name FileClear.
Selects if the contents of the log file are maintained or wiped on runtime start.
Yes: Log file is automatically cleared
No: Log file is maintained and appended
TimeStamp
This property is of type Fixed list of ints and can be referenced with the variable name TimeStamp.
US Date Format
This property is of type True or false and can be referenced with the variable name TimeStamp1::USDate.
Specifies the format of the date string.
No - "DD/MM/YY"
Yes - "MM/DD/YY"
