Component: String Translator (Storage)
Author | Matrix TSL |
Version | 1.0 (Release) |
Category | Storage |
String Translator component
A simple component to allow multiple language support by substituting different strings depending on the selected language.
Simple example showing how to use the translation component when designing multi-language user interfaces.
Clicking the buttons on the keypad selects the active language.
1=English
2=French
3=German Translations Demo
GetTranslation
Gets the current translated version of the string
- BYTE Language
- Range 0 - 7, 0=Default language
Simulation macro reference
Language Count
This property is of type Unsigned integer and can be referenced with the variable name LanguageCount.
Selects how many languages are present and controllable via the component.
Range 1 - 8.
String0 (default)
This property is of type Line of text and can be referenced with the variable name String0.
String used when language parameter set to 0
String1
This property is of type Line of text and can be referenced with the variable name String1.
String used when language parameter set to 1
String2
This property is of type Line of text and can be referenced with the variable name String2.
String used when language parameter set to 2
