Component: Injector (AT) (Comms)
Author | Matrix Ltd |
Version | 1.1 (Release) |
Category | Comms |
This inherits from Data Injector Template |
Injector (AT) component
Comms data injector to replicate basic AT command syntax. The component will record each incoming character until the termination character is received. Once this happens the component will respond by echoing back the received data followed by an "OK" reply.
GSM Example File GSM Example Example should show the following on the display on the panel and on the hardware.
The AT injector component allows us to simulate the response of the GSM module.
This component does not contain any downloadable macros
Simulation macro reference
This component inherits simulation macros from Data Injector Template
InitialiseInjector
- <- STRING InjectorName
- Name of the console that will be created
RxByteCount
Returns the number of bytes currently sat in the receive buffer.
TxByte
- BYTE DataByte
RxByte
Attempt to receive a byte back from the injector
0 - 255 = Valid data
256 = RX timeout no data available
GetTxConsoleHandle
This call is provided by Data Injector Template
ChangeState
Changes the state for I2C or SPI type comms where the data bytes along are not enough to go on.
- BYTE NewState
- Assigns new state, 0=default
GetRxConsoleHandle
GetConsoleHandle
Circular Buffer Size
This property is of type Unsigned integer and can be referenced with the variable name CircularBufferSize.
Amount of room in the circular buffers before running out of memory.
e.g. max command that can be recorded.
Termination Character
This property is of type Fixed list of ints and can be referenced with the variable name TermChar.
Character that will trigger the AT Injector to automatically switch from recording to repeating.
