Component: Barometer (BME280) (Sensors)
Author | Matrix TSL |
Version | 1.3 (Release) |
Category | Sensors |
Barometer (BME280) component
A small PCB surface mount barometric pressure sensor with a I2C bus interface. Pressure range 300 to 1100 hPa. Temperature range -40 to +85 °C. Works with I2C interface only.
ReadPressureFloat
Reads the pressure as a floating point value in Bars.
Calls the ReadPressureRaw function and then converts to a meaningful value.
Reset
Resets the device
I2C_Read_Register
Reads a byte value from a register on the device
- BYTE Address
ReadTemperatureFloat
Reads the temperature as a floating point value in °C.
Resultion sets the return bit value and conversion time.
Calls the ReadTemperatureRaw function and then converts to a meaningful value.
Forced_Read
I2C_Write_Register
Writes a byte value to a register on the device
- BYTE Address
- BYTE Value
ReadHumidityFloat
Reads the humidity as a floating point value in percentage 0-100%.
Calls the ReadHumidityRaw function and then converts to a meaningful value.
Uninit
Uninitialse and release I2C resources
Starts up the I2C bus and initialises the pressure sensor ready for use.
Returns 1 for a sucessful startup.
Returns 0 for a failed startup or no device detected.
Simulation macro reference
Slave Address
This property is of type Fixed list of ints and can be referenced with the variable name SlaveAddress.
This property is of type Fixed list of ints and can be referenced with the variable name cal_i2c1::CHANNEL.
Channel selection
Baud Select
This property is of type Fixed list of ints and can be referenced with the variable name cal_i2c1::BAUD_LIST.
This property is of type Signed integer and can be referenced with the variable name cal_i2c1::BAUD.
Baud rate to be used
Stop Delay
This property is of type True or false and can be referenced with the variable name cal_i2c1::StopDel.
On older microcontroller devices there is a potential for the I2C hardware channel to lock up if there is not
a 10ms delay between an I2C stop event and the next I2C start event.
Most modern microcontrollers will not have a problem so this property can be disabled to speed up the
I2C communications.
SDA
This property is of type Single digital pin and can be referenced with the variable name cal_i2c1::SDA.
SCL
This property is of type Single digital pin and can be referenced with the variable name cal_i2c1::SCL.
Compensation
This property is of type Fixed list of ints and can be referenced with the variable name Compensation.
Compensation formulas in double precision floating point or 32 bit fixed point
Humidity Oversampling
This property is of type Fixed list of ints and can be referenced with the variable name HO.
Pressure Oversampling
This property is of type Fixed list of ints and can be referenced with the variable name PO.
Temperature Oversampling
This property is of type Fixed list of ints and can be referenced with the variable name TO.
Mode
This property is of type Fixed list of ints and can be referenced with the variable name Mode.
Standby Normal Mode (ms)
This property is of type Fixed list of ints and can be referenced with the variable name Stby.
Filter Coefficient
This property is of type Fixed list of ints and can be referenced with the variable name FC.
This property is of type True or false and can be referenced with the variable name cal_i2c1::ScopeTraces.
Selects if the component pin connections are automatically generated on the data recorder window or not.
Yes: Automatically add the component pins to a group on the data recorder which will reflect the sim data during simultion.
No: Do not show the pin signals on the data recorder window.
This property is of type True or false and can be referenced with the variable name cal_i2c1::ConsoleData.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name cal_i2c1::Injector.
