Component: MIAC Advanced (MIAC: Addon Modules)
Author | Matrix TSL |
Version | 1.0 (Release) |
Category | MIAC: Addon Modules |
- 1 MIAC Advanced component
- 2 Examples
- 3 Downloadable macro reference
- 3.1 UART_ReceiveChar
- 3.2 PWM_Enable
- 3.3 MI2C_Send_Byte_Transaction
- 3.4 RTC_Read_Time
- 3.5 RTC_Set_Date
- 3.6 SPI_Uninit
- 3.7 MI2C_Stop
- 3.8 DAC_WriteChannels
- 3.9 UART_SendString
- 3.10 SPI_Init
- 3.11 RTC_Reg_Write
- 3.12 MI2C_Restart
- 3.13 LED_Control
- 3.14 RTC_Read_Date
- 3.15 SPI_Get_Char
- 3.16 UART_Initialize
- 3.17 SPI_Send_Char
- 3.18 MI2C_Transmit_Byte
- 3.19 Sensor_Read
- 3.20 MI2C_Init
- 3.21 MI2C_Receive_Byte
- 3.22 PWM_Disable
- 3.23 RTC_Reg_Read
- 3.24 MI2C_Receive_Byte_Transaction
- 3.25 DigitalOutput
- 3.26 DAC_Write
- 3.27 AnalogInput
- 3.28 Initialize
- 3.29 RTC_Get_Data
- 3.30 RTC_Set_Time
- 3.31 UART_ReceiveString
- 3.32 PWM_SetDuty
- 3.33 MI2C_Start
- 3.34 DigitalInput
- 3.35 UART_SendChar
- 4 Simulation macro reference
- 5 Property reference
Advanced Addon for MIAC System
UART_ReceiveChar
- BYTE Timeout
PWM_Enable
Enable the PWM on Channel 1 or 2
- BYTE Channel
- PWM Channel 1 or 2
- BYTE Device_ID
- BYTE AddrH
- BYTE AddrL
- BYTE Data
RTC_Read_Time
- BYTE HMS
RTC_Set_Date
- BYTE Day
- BYTE Month
- BYTE Year
SPI_Uninit
MI2C_Stop
DAC_WriteChannels
Wrtie values to both DAC Channels
- INT ChannelA
- INT ChannelB
UART_SendString
- <- STRING Text
SPI_Init
RTC_Reg_Write
- BYTE Reg
- BYTE Value
MI2C_Restart
LED_Control
Sets the indicator LED On (State=1) or Off (State=0)
- BYTE State
RTC_Read_Date
- BYTE DMY
SPI_Get_Char
UART_Initialize
SPI_Send_Char
- BYTE Char
MI2C_Transmit_Byte
- BYTE Data
Sensor_Read
- BYTE Sensor
- BYTE HiRes
MI2C_Init
MI2C_Receive_Byte
- BYTE Last
PWM_Disable
Disable the PWM on Channel 1 or 2
- BYTE Channel
RTC_Reg_Read
- BYTE Reg
- BYTE Device_ID
- BYTE AddrH
- BYTE AddrL
DigitalOutput
Set a Terminal Output to High (Value=1) or Low (Value=0)
- BYTE Terminal
- BYTE Value
DAC_Write
- BYTE Channel
- INT Value
AnalogInput
Read the ADC value of a Terminal
Returns 12 bit ADC reading
- BYTE Terminal
- Terminal number to be read
Initialize
Forces a software reset on the module
RTC_Get_Data
RTC_Set_Time
- BYTE Hour
- BYTE Min
- BYTE Sec
UART_ReceiveString
- BYTE Timeout
- BYTE NumBytes
PWM_SetDuty
Sets the PWM Duty cycle on Channel 1 or 2
- BYTE Channel
- BYTE Duty
- Duty cycle (8 bit value)
MI2C_Start
DigitalInput
Read the value of a terminal
- BYTE Terminal
UART_SendChar
- UINT Character
Module Type
This property is of type Fixed list of ints and can be referenced with the variable name MODULE_TYPE.
Module Address
This property is of type Fixed list of ints and can be referenced with the variable name ORDINAL.
Period Overflow
This property is of type Unsigned integer and can be referenced with the variable name PERIOD.
Prescaler
This property is of type Fixed list of ints and can be referenced with the variable name PRESCALER.
Frequency (KHz)
This property is of type Floating point and can be referenced with the variable name PWM_FREQ.
Period (uS)
This property is of type Floating point and can be referenced with the variable name PWM_PERIOD.
This property is of type Unsigned integer and can be referenced with the variable name BAUD1.
Data Bits
This property is of type Fixed list of ints and can be referenced with the variable name BITS1.
Return Type
This property is of type Fixed list of ints and can be referenced with the variable name RET1.
Echo
This property is of type Fixed list of ints and can be referenced with the variable name ECHO1.
Flow Control
This property is of type Fixed list of ints and can be referenced with the variable name FLOW1.
Rate
This property is of type Fixed list of ints and can be referenced with the variable name SPI_RATE.
Prescale option selector
Clock Polarity
This property is of type Fixed list of ints and can be referenced with the variable name CKP.
Clock Phase
This property is of type Fixed list of ints and can be referenced with the variable name CKE.
Sample Point
This property is of type Fixed list of ints and can be referenced with the variable name SMP.
Data bit read sample point
Baud Select
This property is of type Fixed list of ints and can be referenced with the variable name I2C_BAUD.
Slew Rate Control
This property is of type Fixed list of ints and can be referenced with the variable name I2C_SRC.
Slew Rate Control Enabled or Disabled
SMBus Inputs
This property is of type Fixed list of ints and can be referenced with the variable name I2C_SMB.
When Enabled input logic thresholds are compliant with SMBus specification
