Recent Changes - Search:
Introduction to Microcontroller Programming
About PICmicro Chips
Clocking Your PICmicro Devices
E-Blocks
Flowcode Step By Step
PICmicro Projects
Labs
Introduction and Lesson Plan
<^< 7-Segment Decoder Driver | Course Index | 1. Output >^>
Flowcourse lesson plan
From this point on, to do all the labs, you will need:
  • Flowcode 4
  • E-Blocks Multiprogrammer
  • E-Blocks LED board
  • E-Blocks Switch board
  • E-Blocks LCD board
PartTitleDescription
AStep-by-step 1-8Take time to work through the step-by-step section from the first lesson up till the lesson on the 'Goto' or Connection Point icon.
BHelp fileTake time to get to know your way around the help file inside Flowcode. You will have to be able to use the help file whenever you get stuck.
Part Title Estimated time
C Lab 1 - Output 3 - 4 hours
D Lab 2 - Delay 1 - 2 hours
E Lab 3 - Connection Point 1 - 2 hours
F Lab 4 - Calculations 1 - 2 hours
G Lab 5 - Loop 2 - 3 hours
H Lab 6 - Input 3 - 4 hours
I Lab 7 - Decision 5 - 6 hours
J Lab 8 - LCD 5 - 7 hours
Total 21 - 30 hours
From this point on, to do all the exercises, you will need:
  • Flowcode 4
  • E-Blocks Keypad board
  • E-Blocks Sensor board
  • E-Blocks 7-seg. board
  • E-Blocks Patch board
  • LM35 or LM34 temp sensor
KStep-by-step 9-12Take time to work through the Step-by-step section from 7-segment display onwards.
L Lab 9 - Keypad 5 - 8 hours
M Lab 10 - Analogue + EEPROM 8 - 11 hours
N Lab 11 - Software Macro 1 - 2 hours
O Lab 12 - External Interrupt 3 - 4 hours
P Lab 13 - Timer Interrupt 7 -10 hours
Total 24 - 35 hours
Q Project 1 ?
R Project 2 ?
<^< 7-Segment Decoder Driver | Course index | 1. Output >^>
Print - Search - Login
Page last modified on May 14, 2013, at 01:46 PM
