PIC16F15xx Family support
Posted: Wed Nov 29, 2023 8:11 am
by celebriums
Dear Ben and administrators of the Flowcode family, warm greetings to everyone from Istanbul.
Today I will do a project and I want to use PIC16F1516 in this project.
Previously this processor was supported in older versions of Flowcode.
https://www.matrixtsl.com/mmforums/view ... hp?t=11101
However, I could not see this processor support in Flowcode 9.
Can you please add these files?
Thank you everyone in advance.
Re: PIC16F15xx Family support
Posted: Wed Nov 29, 2023 8:11 pm
by celebriums
I have created an FCD file regarding this issue, but due to a mismatch in the CRC code, FLOWCODE is unable to read this file.
I urgently need your help with this matter.
Posted: Wed Nov 29, 2023 9:07 pm
by LeighM
Try deleting the header from the fcd file, down to just before the <root> tag
Posted: Thu Nov 30, 2023 5:26 am
by celebriums
Unfortunately it didn't happen. I guess the CRC isn't the only protection.
Posted: Thu Nov 30, 2023 10:54 am
Would you like to try this fcdx file?
Browse to this location using File Explorer, it's hidden by default so just paste the link into your address bar.
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\PIC\
If Flowcode is already open, then you will need to reload your project.
If you run any component updates, then the fcdx you added will be overwritten.
Note: you won't see any data within the fields when selecting 16F1516.
Posted: Thu Nov 30, 2023 1:07 pm
by celebriums
Currently the code is working properly. Thank you for your quick support.
I just noticed that the following line is different, will this cause a problem in the future?
Your Code
268: <start code='\nvoid main()\n{\n\t#ifdef INTOSCHELPER\n\t\t\tINTOSCHELPERCODE\n\t#endif\n\n\n\n' />
Original:
268: <start code='\nvoid main()\n{\n' />
Posted: Thu Nov 30, 2023 2:05 pm
You're welcome.
I have not edited that line.
The one you are comparing with is from a much older version of Flowcode.
The fcdx file I posted is for FC9.
