PIC16F15xx Family support
celebriums
Has thanked: 25 times
Been thanked: 13 times
Post by celebriums »
Dear Ben and administrators of the Flowcode family, warm greetings to everyone from Istanbul.
Today I will do a project and I want to use PIC16F1516 in this project.
Previously this processor was supported in older versions of Flowcode.
https://www.flowcode.co.uk/mmforums/vie ... hp?t=11101
However, I could not see this processor support in Flowcode 9.
Can you please add these files?
Thank you everyone in advance.
Sadık Süme
celebriums
Re: PIC16F15xx Family support
I have created an FCD file regarding this issue, but due to a mismatch in the CRC code, FLOWCODE is unable to read this file.
I urgently need your help with this matter.
Sadık Süme
Has thanked: 110 times
Been thanked: 302 times
Try deleting the header from the fcd file, down to just before the <root> tag
celebriums
Unfortunately it didn't happen. I guess the CRC isn't the only protection.
Snap 2023-11-30 at 08.25.19.png (149.43 KiB) Viewed 8207 times
Sadık Süme
Has thanked: 795 times
Been thanked: 858 times
Would you like to try this fcdx file?
Browse to this location using File Explorer, it's hidden by default so just paste the link into your address bar.
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\PIC\
If Flowcode is already open, then you will need to reload your project.
If you run any component updates, then the fcdx you added will be overwritten.
Note: you won't see any data within the fields when selecting 16F1516.
16F1516.fcdx
(18.3 KiB) Downloaded 748 times
celebriums
Currently the code is working properly. Thank you for your quick support.
I just noticed that the following line is different, will this cause a problem in the future?
Your Code
268: <start code='\nvoid main()\n{\n\t#ifdef INTOSCHELPER\n\t\t\tINTOSCHELPERCODE\n\t#endif\n\n\n\n' />
Original:
268: <start code='\nvoid main()\n{\n' />
Snap 2023-11-30 at 15.56.21.png (342.4 KiB) Viewed 8189 times
Sadık Süme
You're welcome.
I have not edited that line.
The one you are comparing with is from a much older version of Flowcode.
The fcdx file I posted is for FC9.
