Page 2 of 2
Re: ESP CANbus not compiling
Posted: Mon Sep 29, 2025 7:55 pm
by BenR
The only thing you should need to do is to use the library updates tool from the help menu. This should give you the latest can driver that should allow internal can to compile.
Posted: Tue Sep 30, 2025 5:07 pm
by Dutch
That i have done (more than ones
) plus clean new install and its showing these versions for ESP (screenshot in attachments).
still compiling with 'can.h" build failed.
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ESP\ESP_CAL_CAN.c:150:10: fatal error: driver/can.h: No such file or directory
150 | #include "driver/can.h"
compilation terminated.
ninja failed with exit code 1
Running ninja in directory C:\FC_ESP\mtxesp32s_sdkconfig\build
Executing "ninja all"...
Build Failed.
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\ESP\Batch\esp32_build.bat reported error code 0x1
Posted: Wed Oct 01, 2025 3:16 pm
by BenR
Ok that's odd, I've pushed the change to the update system again.
Posted: Wed Oct 01, 2025 4:56 pm
by Dutch
BenR wrote: ↑Wed Oct 01, 2025 3:16 pm
YES!
16 updates.
'Build completed sucsessfully'
Back to creating CAN signals ! i'l test asap.
Thank you Ben.
Regards, Angelo.
